Build ESP32 project
Sysprogs forums › Forums › VisualGDB › Build ESP32 project
  • #24378
    Andrzej.T
    Is possible to build ESP32 C-Make project without Visual Studio and VisualGDB?
    Regards,
    Andrzej Tatar
    #24380
    You should be able to do this by reusing the build command line shown in the VisualGDB build log (you can find the CMake parameters in View->Output->Advanced VisualGDB Project Output when opening the project), however you may need to setup some additional environment (e.g. cmake/ninja paths).
    #24383
    Andrzej.T
    When I try build using C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe command it work, but not work with downloaded ninja from https://ninja-build.org/.
    Do you have a special version of ninja ?
    Regards,
    Andrzej Tatar
    #24384
    The version shipped with VisualGDB was also downloaded from the official Ninja site, although it’s likely a different version.
