BSP-Packages Location
Sysprogs forums › Forums › VisualGDB › BSP-Packages Location
  • #27339
    runout
    the BSP-Packages are stored under “c:\Users\<User>\AppData\Local\VisualGDB\”
    (for each user separately) Size approx. 2,5GB in my case
    Is it possible to put the BSP-Packages to a one/common place?
    Kind Regards
    Runout
    #27350
    Yes, please consider following our BSP relocation tutorial.
    #27373
    runout
    OK, thanks for your advice.
    Do I absolutely need the “Custom or higher” – Version?
    Is it possible to tweak the BSP_ROOT variable?
    (in “FindBSP.props” e.g.)
    Kind Regards
    #27379
    The only officially supported way to do so is to use the Custom edition or higher.
