Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Bluescreen during boot Windows 7 [VirtualKD], x64
- This topic has 4 replies, 2 voices, and was last updated 13 years ago by
jacob374.
September 23, 2011 at 08:25 #357
Gelbaerchen
ParticipantHello, during booting my virtual W7, x64 machine (using VirtualBox 4.0.12) the boot hangs and VS2010 shows the following output. Booting this virtual machine without VirtualKD works fine and also using the boot option [VirtualDK] on a virtual machine using XP SP3 works fine. My host system is also W7, x64 prof. I checked VBoxDD.dll and VBoxDD0.dll … what else could I do?
Thanks for any idea
______________________________________________________________________Evaluation complete in 0 ms
Loaded PDB symbols for 47 out of 51 modules
*** Fatal System Error: 0x00000124
(0x0000000000000000,0x0000000000000000,0x0000000000000000,0x0000000000000000)A fatal system error has occurred.
Debugger entered on first try; Bugcheck callbacks have not been invoked.A fatal system error has occurred.
Connected to Windows 7 7601 x64 target at (Fri Sep 23 10:09:27.503 2011 (UTC + 2:00)), ptr64 TRUE
Loading Kernel Symbols
Loading User Symbols*******************************************************************************
* Bugcheck Analysis *
*******************************************************************************Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, 0, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
!analyze -v
*******************************************************************************WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: 0000000000000000, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: f
STACK_TEXT:
fffff880`009ef408 fffff800`027b5ae2 : 00000000`00000000 fffff880`009eff40 00000000`00000065 fffff800`02706718 : nt!RtlpBreakWithStatusInstruction
fffff880`009ef410 fffff800`027b68ce : 00000000`00000003 00000000`00000000 fffff800`02706f70 00000000`00000124 : nt!KiBugCheckDebugBreak+0x12
fffff880`009ef470 fffff800`026cad44 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheck2+0x71e
fffff880`009efb40 fffff800`027db5d0 : 00000000`00000124 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx+0x104
fffff880`009efb80 fffff800`026117a1 : fffffa80`0135f040 fffff880`009efd10 fffff880`009efc70 fffff800`0262e2b0 : nt!WheaReportHwError+0x320
fffff880`009efbe0 fffff800`0277d8a1 : fffff880`009efdb0 00000000`00000001 00000000`00000001 00000000`00000000 : hal!HalHandleNMI+0x149
fffff880`009efc10 fffff800`026c7f82 : fffff880`009e5180 00000000`00000000 00000000`00000000 00000000`00000001 : nt!KiProcessNMI+0x131
fffff880`009efc70 fffff800`026c7de3 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxNmiInterrupt+0x82
fffff880`009efdb0 fffff800`026d6c0f : fffff880`009e5180 fffff880`02e5bb80 fffffa80`021b95a0 00000000`00000000 : nt!KiNmiInterruptStart+0x163
fffff880`02e5bb00 fffff800`026227d2 : fffff800`026d45e4 fffffa80`0135f040 fffffa80`021b95a0 fffff880`009eff40 : nt!KiSecondaryClockInterrupt+0x5f
fffff880`02e5bc98 fffff800`026d45e4 : fffffa80`0135f040 fffffa80`021b95a0 fffff880`009eff40 00000000`00000002 : hal!HalProcessorIdle+0x2
fffff880`02e5bca0 fffff800`026c293c : fffff880`009e5180 fffff880`009eff40 00000000`00000000 fffff800`027f0ef0 : nt!PoIdle+0x665
fffff880`02e5bd80 00000000`00000000 : fffff880`02e5c000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x2cSTACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_NOERRREC
March 10, 2013 at 12:12 #1972Gelbaerchen
Participanthmm … now I installed the latest VisualDDK 1.5.7, up- and downgraded the virtualbox versions from 4.2.4 to 4.2.8 and to 4.1.22 but I’m still running exactly into this BSOD during booting the VirtualBox W7 x64 machine. Is there nobody else having this problem?
March 10, 2013 at 12:47 #1973Gelbaerchen
ParticipantNow I’ve done some changes in the system settings of my VirtualBox and the problem seems to be related to the number of CPUs. First I tried 2 CPUs and I had the bluescreen, now I’m using a single CPU and I can boot my VirtualBox W7 64 in Virtual KD debug mode without bluescreen 😉
June 12, 2013 at 11:17 #1974Gelbaerchen
ParticipantMy only solution so far ist to use a single CPU virtual machine.
October 7, 2013 at 12:18 #1975jacob374
Participantthe virtualbox versions from 4.2.4 to 4.2.8 and to 4.1.22 but I’m still running exactly into this BSOD during booting the VirtualBox W7 x64 machine.
http://www.umw.edu/
http://www.microsoft.com/
http://www.pass4-sure.us/CCNP-training.html
https://www.facebook.com/Microsoft
http://www.youtube.com/user/CompTIATV -
