Better FreeRTOS debugging like NXP
Sysprogs forums Forums VisualGDB Better FreeRTOS debugging like NXP
Viewing 11 posts - 1 through 11 (of 11 total)
  • #21377
    VasiliSk
    Hello, i have google-d a little and didn’t find answer, do you have similar functionality now?
    Better FreeRTOS Debugging in Eclipse
    I find heap and stack usage very helpful for fixing mem leaks. There is a table of all allocated memory locations and free areas
    Also i have tested VisualGDB and did’t see task names in threads
    #21380
    Thanks for the suggestion, we will consider adding detailed allocation analyzer to one of the next VisualGDB releases.
    Currently VisualGDB supports FreeRTOS thread names through an open-source plugin (requires the custom edition or higher, should fully work in trial mode). If it doesn’t work, please share a diagnostic gdb log and a screenshot of the Threads window and we will investigate.
    Although VisualGDB currently won’t show dynamically allocated regions, it can highlight the bounds of global variables and stack frames in the memory window. Simply use the advanced memory window and enable global variable highlighting via the toolbar.
    #21391
    VasiliSk
    Thanks, i will keep an eye for these features
    #26165
    MichalPeterek
    Hi what’s happened with this function ?
    #26166
    It is still on the roadmap, however it is hard to give any estimates currently, we are prioritizing a few other features over it, sorry.
    #26167
    MichalPeterek
    Ok, can you tell me how can I open this view ?
    #26171
    MichalPeterek
    Can you delivery for me VisualGDBExtensibility dependency ? I can continue this code on github and add Queue watch table.
    #26231
    You can open the Threads view using the Debug->Windows->Threads command in Visual Studio
    The VisualGDBExtensibility.dll library is shipped with VisualGDB (normally C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDBExtensibility.dll). Simply add it as a reference to the project referencing it and you should be able to build it.
    #28095
    VasiliSk
    Any progress on rtos stack usage? I’m still waiting 🙂
    #28096
    Yes, please try VisualGDB 5.5 Preview 5: https://sysprogs.com/w/announcing-visualgdb-5-5-preview-5/
    #28098
    VasiliSk
    okay, shut up and take my money 😀
