Sysprogs forums › Forums › WinCDEmu › Basiz…we wait you!
- This topic has 31 replies, 4 voices, and was last updated 11 years, 7 months ago by
Anonymous.
October 2, 2012 at 13:43 #561
ParticipantHi Basiz,
When the new portable version come out?We need only some simply feature, but you can make a new version in 2 minute.
Take the last 3.6 source, open the file batchmnt.cppand change this line:VirtualCDClient clt(&status);To
VirtualCDClient clt(&status, true);In this way we can use the portable driver instead of installed driver, you need only to create a button for “Uninstall” and “install” driver
Last thing, add at the last line of the uninstalling driver process this CMD command:
driverqueryFor refresh and not give the error:
The specified service has been marked for deletionI have try to do by myself but everytime i have 10.000 error, and i’m using BazisLib….
For you it’s only 2 minute, please give to us a new portable version with batchmntPLEASE!
October 12, 2012 at 18:29 #2385Anonymous
ParticipantCome’on Bazis…you have some respect for people using you software? We don’t want many changes/feature, but something really simple for you but very important for us.
Can you change two line of code or you don’t have time?Sorry for being rude, but it’s not fun to wait many years ( yes, years ) for a new portable version.
October 13, 2012 at 18:34 #2386Anonymous
ParticipantI’d like to see a new portable version with that feature, a command line can be very useful
October 26, 2012 at 21:05 #2384support
KeymasterHi, guys. Sorry for the delay, got far too many things to do.
Try this build: http://wincdemu.sysprogs.org/portable/PortableWinCDEmu-3.6.exe
Note that it has not been through the usual testing cycle, so feel free to report any bugs…October 28, 2012 at 14:18 #2368Anonymous
ParticipantThanks for the new version. First two problem:
1) The .exe says 3.6 but the GUI 3.4, it’s not a problem but i don’t know if you know
2) Always same problem about uninstalling
Try by yourself:
1) Open WinCDEmu
2) Click OK – Install driver
3) Uninstall the driver
4) Open Wincdemu
5) Click OK – Install driver
6) ERROR:
Driver installation failed:
The specified service has been marked for deletionWe have only two solution
1) Reboot the system and WinCdEmu can install the driver
2) Open cmd –> type “driverquery” without quotes and WinCdEmu can install the driver
The solution is easy, add a driverquery command after the driver uninstalling3) What about the batchmng?
Maybe is cool to add the command line, it’s the most feature request. And maybe add the option to install/uninstall the driver throught commandline, i have talked with some user of the forum and the agreeThanks and have a nice day 😉
October 28, 2012 at 14:26 #2369Reten
ParticipantI agree with Thunder for everything he wrote.
Bazis I’ll answer here because the argument is the same, i don’t use the portable versione because the batchmnt not recognize the portable driver, so if you can add a command line for the portable version i’ll use the new portable version
I’d like also the opportunity, as Thunder said, to install / uninstall the driver directly from the command line, so is useless to use of devcon.Another little feature request.
It’s better to add an option to remove the ISO and not the drive itself, can create problem with multi-iso installationThanks for everything, really.
October 29, 2012 at 08:28 #2370Anonymous
ParticipantHi i have tested the new version, i can confirm:
1) The uninstalling driver problem, and i can confirm also the solution, just write on cmd “driverquery”
1) The version 3.4 instead 3.6 on the main windowAfter uninstalling the driver, WinCDEmu leaves some traces on the register, here:
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicesBazisPortableCDBusHKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesBazisPortableCDBusHKEY_LOCAL_MACHINESYSTEMControlSet001EnumRootLEGACY_BAZISPORTABLECDBUSHKEY_LOCAL_MACHINESYSTEMCurrentControlSetEnumRootLEGACY_BAZISPORTABLECDBUSYou have forgot to remove those key and subkey after uninstalling? It’s the portable version, so you need to remove all the traces on the register.
And i agree also in this new feature:
1) The batchmnt for the portable version, with the feature for install/uninstall the driver
2) Add a feature for remove the ISO, not the drive directlyI’m so happy for this new version 😉
October 31, 2012 at 14:07 #2371Anonymous
ParticipantThere is nothing to say in addition to what has already been said, hope Basiz take in consideration the previus post for make the software really perfect, it will be the last major update, the last effort 😀
November 6, 2012 at 16:08 #2379Anonymous
ParticipantI’m waiting for the new version, and all the new feature, like other 😉
November 10, 2012 at 09:00 #2378Anonymous
ParticipantNo more news from basiz? He working on it?
November 12, 2012 at 09:33 #2377Anonymous
Not yet…hope he working on the new version and follow our suggestion 😉
November 16, 2012 at 12:53 #2372Anonymous
ParticipantThanks for the answer Thunder
November 27, 2012 at 07:14 #2382Anonymous
ParticipantMmm so? We wait you Basiz 😉
November 28, 2012 at 13:32 #2383Anonymous
ParticipantWaiting for news 😥
December 27, 2012 at 14:20 #2374Anonymous
Participantbump
