Attach to Process: "Don't stop the process after attaching" by default?
Sysprogs forums Forums VisualGDB Attach to Process: "Don't stop the process after attaching" by default?
  • #23354
    MiloDC
    In the “Attach to Process” window, how do I enable the “nostop” feature by default?
    I always have to click “Find…” and then set the option manually.  I’d much rather just have “,nostop” always appended to the connection target.
    VisualGDB nostop
    • This topic was modified 7 years, 2 months ago by MiloDC.
    #23356
    Do you use the “Find” button to find the target? If yes, we could make it remember the last state of the flags for each target.
    #23357
    MiloDC
    No, sometimes I’ll just append “,nostop” directly to the connection target field, after selecting a target in the drop-down.
    I should be able to specify “nostop” as a property on the connection targets themselves (e.g. in the SSH Host Manager).
    • This reply was modified 7 years, 2 months ago by MiloDC.
    #23367
    No problem. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.100.2728.msi
    It will remember the last used host selected via the “Find” button and the “nostop” flag. You will be also able to add/remove the “,nostop” part manually just as before.
    #23459
    MiloDC
    Doesn’t work.  When I reopen the Attach to Process window, there’s still no option in the “Connection target” drop-down that’s appended with “,nostop.”  I still have to add the option manually (either by typing it, or by opening the “Find…” window and clicking the option box).
    Also, how do I hide/turn off the reference links above my functions/methods?
    #23464
    Please try enabling the option in the “Find” window and then restart Visual Studio. Next time you start it, “nostop” will be automatically added to all entries in the target list.
    You can disable the CodeJumps references by clicking at the tag button in the top right corner of the screen.
    #23469
    MiloDC
    Success!  Thank you for the superb customer service!
    Again, thanks!
