Sysprogs forums › Forums › VisualGDB › ARM Toolchain Missing Files
- This topic has 3 replies, 2 voices, and was last updated 3 years, 4 months ago by
November 23, 2022 at 09:28 #33465
kurt123
ParticipantHi there,
I am using the embedded ARM Toolchain that is installed through the VisualGDB package manager (GCC 10.3.1; GDB 10.2.90). The toolchain’s
arm-none-eabi\include\c++\10.3.1directory appears to be missing files. For instance, the standard C++stringfile attempts to includebits/c++config.h, however this file does not exist in the toolchain. So, if I try to use C++ strings, my build breaks.Does anyone know what is happening here and how I can fix it?
All help is appreciated 🙂
Thank you for reading this.
November 23, 2022 at 09:44 #33466support
We have just rechecked our ARM toolchain and it works just fine. Most likely, you have configured something incorrectly on our side.
We will monitor the issue and will consider investigating it further if other users report similar issues.
November 23, 2022 at 11:46 #33467kurt123
ParticipantIt looks like I am running the C compiler rather than the C++ compiler. Is there a setting to change the compiler?
November 23, 2022 at 11:48 #33468support
