ARM Semi-Hosting question
Sysprogs forums › Forums › VisualGDB › ARM Semi-Hosting question
  • #20389
    sidprice
    I am using the above to help debug and trace my project code, however I am not sure what to do for my production code.
    In the settings for my embedded project I can disable semi-hosting, do I also need to remove the “printf” calls that were sending output through the debug pod using semi-hosting?
    Thank you,
    Sid
    #20391
    Yes, you would need to remove the calls to printf(). The easiest way to do this would be via using conditional compilation, e.g.
    #ifdef _DEBUG
    #define LOG(...) printf(__VA_ARGS)
    #else
    #define LOG(...)
    #endif
    #20394
    sidprice
    Excellent, thanks again,
    Sid
