Application won't execute on RPi
Sysprogs forums Forums VisualGDB Application won't execute on RPi
  • #6948
    jblook
    I’m a bit of a newbie when it comes to compiling on the Raspberry Pi. I tried using VisualGDB, which works great for debug.
    The thing is, i cannot seem to run my resulting executable on the RPi (Raspbian) without the debugger.
    I’m getting an error claiming “Syntax error: word unexpected (expecting “)”).
    Google searches show this error in various contexts, but none helped me solve the issue.
    Thanks in advance…
    #6959
    Does it happen when you hit Ctrl-F5, or when you launch it manually on Raspberry Pi via SSH? Do you have any special environment/command-line arguments set? Does the deployment directory path contain any special characters?
    #6969
    jblook
    Thanks for your reply. I was referring to launching it manually via SSH. Checking the CTRL-F5 option, which i wasn’t aware of until now, works too.
    I didn’t change any of the folder settings, and on my local drive it’s saved on C:\my_project_name (with underscores, obviously a different name :)).
    Thanks…
    #6971
    Good to know it works now. If you encounter this problem again, please attach a screenshot of the error showing the exact command you are using and SmarTTY output. This should help understand what could be causing it.
    #6972
    jblook
    It’s working now.
    I’m new to Linux. Apparently I had to do ./<filename>.
    I also did chmod +x prior to that. Don’t know if that’s the reason.
    I suspected there was some linux-y “simon-says” kind of a thing that i was missing. 🙂
    Thanks again!
