All Custom Build steps failing
Sysprogs forums › Forums › VisualGDB › All Custom Build steps failing
  • #34720
    dwarnow-xylem
    I am trying to execute pre-build steps on multiple embedded projects across multiple platforms.  No commands seem to work, even commands as simple as Echo fail.
    Below is an example of the commands which are failing the build from the vgdbproj file.  I have them skipped here because they were failing the build, but that is not the issue.
    <PreBuildActions>
    <CustomActionBase xsi:type="CommandLineAction">
    <SkipWhenRunningCommandList>true</SkipWhenRunningCommandList>
    <RemoteHost>
    <HostName>BuildMachine</HostName>
    <Transport>BuiltinShortcut</Transport>
    </RemoteHost>
    <Command>cmd /c "echo test"</Command>
    <WorkingDirectory>$(BuildDir)</WorkingDirectory>
    <BackgroundMode>false</BackgroundMode>
    </CustomActionBase>
    <RemoteHost>
    </RemoteHost>
    <Command>cmd /c "cd ../Common/parameters &amp;&amp; python parameter_headercreator.py"</Command>
    </CustomActionBase>
    </PreBuildActions>
    I have tried both the call to cmd ( via cmd /c) and the direct calls and neither method works.
    The log output is as follows:
    Executing pre-build actions
    Run "cmd /c "echo test" " in directory "C:\_Projects\HMI_Prod_Firmware\ESP32" on local computer
    cmd /c "echo test"
    Command exited with code -1
    Executable: cmd /c "echo test"
    Arguments:
    Directory: C:\_Projects\HMI_Prod_Firmware\ESP32
    Command-line action failed
    Thank you.
    #34721
    It looks like you specified both command and arguments together:
    Please use this syntax instead:
    <Command>cmd</Command>
    <Arguments>/c "echo test"</Arguments>
    If you are using the VisualGDB Project Properties window, simply put the /c “echo test” part in the Arguments field.
    #34722
    dwarnow-xylem
    I knew it was going to be a silly problem on my side…  That, of course, fixed the problem.  Thank you so much.
