Hello Sysprogs
Would it be possible to update the “Additional Memories” so you can see for example every flash memory on-chip like uVision5 does it?
It would be much more clear where you save something instead of just choosing between Flash and any sort of RAM.
And my second problem: On my laptop I cant really read the text in the “Addiditon Memories” window because its cut in the half. Even if I add a new memory the text of it is also cut in the half.
My screen resolution: 13.5 inch 3000 x 2000 pixel (Surface Book) and a 3:2 aspect ratio.
See the attached screenshot for uVision memory window.
You must be
