Additional ARMASM arguments in Keil settings not working.
Sysprogs forums › Forums › VisualGDB › Additional ARMASM arguments in Keil settings not working.
  • #33866
    murrellr
    I have imported a Keil uVision project into Visual Studio using the VisualGDB import mechanism.  For an assembly language file I must add the argument “–via version.via”.  The project property pages has a Keil Settings menu item.  One of its fields is “General->Additional ARMASM arguments”.  I added the argument here but the argument does not appear on the armasm.exe command line.  The file “version.via” contains a dynamic predefined symbol that is generated in a pre-build step.  How do I add this argument to the command line.
    Microsoft Visual Studio 2022 Version 17.4.5
    VisualGDB version 5.6R9 (build 4777)
    #33867
    murrellr
    One more piece of information: My toolchain is “Keil ARMClang (Stand-alone) in C:\Keil_v5\ARM\ARMCLANG” Version 6.13.1.  If I select “Keil ARMCC in C:\Keil_v5\ARMCC” Version 5.x, the assembly language file compiles with the “–via version.via”, but the rest of the project fails (I need to use the armclang compiler).
    #33870
    Thanks, this indeed looks like a bug in the logic that prevents the incompatible armclang options from being passed to armasm. We have fixed it in the following build: VisualGDB-5.6.109.4816.msi.
    You can also apply the patch on your side without reinstalling VisualGDB by locating the following statement in the %VISUALGDB_DIR%\MSBuild\Targets\gcc.targets file:
    <ItemGroup Condition="'$(GNUToolchainSubtype)' == 'armclang'">
    	<ClCompile Condition="'%(ClCompile.IsAssemblyFile)' == 'true'">
    		<AdditionalOptions/>
    	</ClCompile>
    </ItemGroup>
    Then, you would need to change the <AdditionalOptions/> line to this:
    <AdditionalOptions>$(ARMASMArguments)</AdditionalOptions>
    #33873
    murrellr
    The installer works well.  Thank you for your prompt response.
