Your edition does not support Linux project
Sysprogs forums Forums VisualGDB Your edition does not support Linux project
  • #6221
    bubusoft
    Hello, I am enthusiast about the VisualGDB for VS2013; I am testing this tool to develop RaspberryPI applications.
    By the way I am experincing some issues. In detail: I am using win8.1, VS2013 community edition. I installed the VisualGDB 43R2 and I tested this software for few days. Then I decided to register myself into the VS2013 community; after this step the VisualGBD stopped working.
    At the first stage it prompted with a message like “your key is corrupted, do you want to repair it” but it failed. So I decided to completelly remove the VS2013 and VisualGDB and start from a fresh installation.
    The fresh installation went ok, but now as soon as I try to build a project using VisualGDB, I am receiving the error “Your edition of VisualGDB does not support Linux projects”. I tryed to create a new project from the scratch but at the first first step of the new project wizard I am experiencing the same error.
    I tried also the new release of the VisualGDB (5) and it is not working too (same error msg).
    I would like to ask your help to have this issue sorted out; I would like to make some test to better understand if this tool is ok for my application.
    Thank you in advance.
    Lorenzo
    #6223
    Please forward your activation key to our support email so that we could see why it is not working.
    #6226
    bubusoft
    Thank you for the prompt reply. Where can i fine that Key? I ma usino the trial version
    Lorenzo
    • This reply was modified 11 years, 6 months ago by bubusoft.
    #6228
    This message could only appear if you have already entered an activation key. If you have not entered one, your registry may be corrupt. Please try installing VisualGDB on a different computer.
