Sysprogs forums › Forums › VisualGDB › Yocto-Linux
- This topic has 42 replies, 2 voices, and was last updated 9 years, 10 months ago by
May 17, 2016 at 17:13 #8232
peter_cz
ParticipantDoes not work.
dialog says:
Could not detect any common problem based on your log. Please contact support@sysprogs.com for further assistance.
May 17, 2016 at 17:49 #8233support
KeymasterOK, this means that the connection between the gdb machine and the target machine cannot be established. Please try the following:
- Manually launch “gdbserver :2000 <deployed binary>” on the target
- Try connecting to 192.168.0.100:2000 via telnet from the gdb machine. If this does not work, try connecting from the Windows machine. If this does not work either, try connecting from the target machine itself.
If the only machine you can connect from is the target machine itself, please check your network & firewall settings. If you can connect from Windows, but not from Linux, check that both machines are on the same network and that no firewall between them is blocking connections.
May 17, 2016 at 18:38 #8234peter_cz
ParticipantI’m able to establish SCP (WinSCP) connection Win -> Target (192.168.0.100) but not telnet 192.168.0.100:2000 while I’m running gdbserver :2000 LinuxProject1 on my target machine. My build (host, Linux) machine (10.171.88.187) supposed to be on the same network as windows one (10.171.88.158) but target is connected via local wifi as PC-Windows <-> Target via wifi router as AP.
May 17, 2016 at 19:43 #8235support
KeymasterOK, so you can telnet to 192.168.0.100:2000 from the target itself, but not from Windows, right? If yes, please try disabling the firewall on the target.
May 18, 2016 at 06:02 #8236peter_cz
ParticipantIt seems gdbserver on target got freeze. Since cmd : gdbserver :2000 myproj
Then got response listening at 2000 but then board has no response and can’t quite gdbserver. Any option to run gdbserver with needed?
May 18, 2016 at 07:21 #8237peter_cz
Participantmy observation:
On my target (IP: 192.168.0.100) I run
gdbserver :2000 LinuxProject1got response
Process LinuxProject1 created; pid = 535Listening on port 2000on my windows machine run Tera Term where setting is
TCP/IP Host: 192.168.0.100
telnet TCP port#2000
Protocol:UNSPEC
then I got response on target:
Remote debugging from host 192.168.0.101May 19, 2016 at 05:24 #8242support
KeymasterOK, this confirms that you can connect from your Windows machine. Could you run “telnet 192.168.0.100 2000” on the Linux machine and see if gdbserver reports an incoming connection like it does when connecting from Windows?
May 19, 2016 at 09:15 #8244peter_cz
ParticipantNope. can’t access it from Linux Host, I have no response on my target by issuing telnet> open 192.168.0.100 no response on target side.
May 19, 2016 at 09:42 #8245peter_cz
ParticipantI got the VisualGDB working. I put the target on the same network as Linux Host & Windows machine and now I got this working!!!
May 19, 2016 at 12:22 #8246peter_cz
ParticipantHello,
I just rebuilt the linux image and want to continue debugging but I hit the issue of establishing connection to target:
SSH: Connecting…
SSH: Error
Connection error: No connection could be made because the target machine activel
y refused it 10.171.88.193:22
Connection to target failed. Please use Tools->SSH Host Manager in Visual Studio
to diagnose it.I can ping to my target both from Windows machine and Linux build host.
Visual C++ says:
Cannot connect : No connection could be made because the target machine actively refused it 10.171.88.193:22
This reply was modified 9 years, 10 months ago by
peter_cz.
May 19, 2016 at 23:59 #8249support
Most likely the new image does not have the OpenSSH server installed. You can install it by logging on via a COM port and running “sudo apt-get install openssh-server”.
May 20, 2016 at 10:37 #8254peter_cz
ParticipantProblem is that within Yocto/Linux I need to build it whatever package i need and there is no package manager for install such as apt-get.
but I did reset my PC, MS Visual, and target linux imx and then I’ve been successful.
It seems to me that old setting is somewhere cached – so some cleanup needed when new target on same IP address is needed but i’m just guessing.
Thank you very much for your support!
May 20, 2016 at 17:38 #8256support
Good to know it works. Let us know if you encounter further problems.
Note that we do recommend using Debian-based Linux distros like Ubuntu as they have convenient package managers that can install most of the commonly used software.
