Xp x64 building – XP win32 debugging via ethernet
Sysprogs forums Forums VisualDDK/VirtualKD discussion Xp x64 building – XP win32 debugging via ethernet
Viewing 1 post (of 1 total)
  • #169
    olebenny
    Hello
    I am trying to setup and debug the driver-example.
    I am building on WinXP X64 VisualStudio2008 and have installed VisualDDK.
    I have created a driver – example as described and it builds.
    My target system is a seperate PC running Win XP(32-bit), and I have started the DDKLaunchMonitor.
    The DDKLaunchMonitor shows: Discovery request from 192.168.200.209, which is my WinXP x64.
    Trying to setup the VisualDDK Driver Project Launcher, I am missing information how to set ‘Named pipe’, as I assume this is the problem.
    It is right now set to kd_VMXPRO ( the default ) , but I get a message box saying:
    VisualDDK: Cannot start debugging: The system cannot find the file specified.
    Is there a place, where I can see ‘which file’ ????
    best regards
    olebenny
