I have set up both a *.xml fliemaks in the Project Settings->File sybcronisation and set an explicit copy config.xml custom debug setting before launching debugger, but neither copy the xml file over?
In the project settings, even when I use the ‘transfer files now’ option the xml file is still not copied. I cant seem to find any debug output to see what files are being copied or possibly failing.
Well not sure why the project settings/file sync does not work. It copies the files to the /tmp/VisualGDB/c/projects/<project> directory. However it does not copy the xml file to the debug directory.
In the pre debug step I set it to copy to /tmp/VisualGDB/c/projects/<project>/VisualGDB/Debug/config.xml (ie, explicitly set the file name) and it works.
Most likely, the *.xml is not mentioned in the copied file masks. If you could share a screenshot of your settings, we should be able check this and help you find the cause.
