Sysprogs forums › Forums › VisualGDB › XMing with OpenCV
- This topic has 5 replies, 2 voices, and was last updated 10 years, 5 months ago by
gomore.
April 26, 2016 at 11:35 #8100
gomore
ParticipantHello.
I´ve got a problem…….I´m trying to test OpenCV projects in a Raspberry following one of your tutorials, this one:
http://visualgdb.com/tutorials/raspberry/opencv/
But I have a problem. It compiles and executes the debugging project correctly, but my problem comes with the XMing. It doesn´t show me anything. It opens two XMing windows(as it has to) but the two of them are totally grey (the Mat objects in the code have data inside when I debug it). May I lose something, any library or component or something??
April 26, 2016 at 18:15 #8108support
First of all, please try running the project on the Linux machine. Does the GUI show correctly? If no, the problem is in the project and not in XMing.
If yes, please try creating a basic Qt project and OpenGL project. If the first one does not show properly, it looks like an Xming bug. If the second one does not, you may be missing OpenGL support.
April 27, 2016 at 09:31 #8121gomore
ParticipantHi.
First thanks for your answer. I tried to run the project on the Linux machine(Raspberry with raspbian), and it opens a QMessageBox propperly and then opens two OpenCV windows but all in grey, neither source image not contour image are shown in the windows. It happens the same running it on the linux machine or on Windows with XMing.
So I tried to create a simple OpenGL project, and it runs well in both XMing under windows and in the local linux machine. So, it seems that something is missing in the project? Any library or something? I have to add OpenGL libraries somewhat in the project? Or are included with the Qt or OpenCV libraries?
April 28, 2016 at 03:15 #8129support
Does the project output any errors to the console? Did you copy the code from the tutorials EXACTLY, or did you modify it? Perhaps you have accidentally bypassed some initialization?
Normally missing libraries should cause link-time errors, but not run-time issues.
Alternatively you can try the same project on a different VM (you can use Vagrant to just download a ready image with some recent OS in just a few clicks).
April 28, 2016 at 15:03 #8130gomore
ParticipantHello again.
The only error I have in the console output is this warning:
“libEGL warning: DRI2: failed to authenticate”
I can´t fix it. I´m reading trough the net that can be a raspberry incompatibillity with OpenGL_ES??
April 28, 2016 at 16:22 #8131gomore
ParticipantProblem solved.
It still gives me the LibEGL warning but now works. It was a little code problem. Next step would be to try to do a video streaming from an IP camera.
Thank nyou so mutch for your help.
