Sysprogs forums › Forums › VisualGDB › x_display = XOpenDisplay(NULL); returns NULL on latest UBUNTU systems
- This topic has 24 replies, 2 voices, and was last updated 6 years, 9 months ago by
Brian Beuken.
June 6, 2019 at 00:56 #25078
Brian Beuken
ParticipantSo after checking around, I was told to check that /etc/ssh/sshd_config had X11Forwarding set to yes
it was.
So I am at a loss, I can build test projects on the Jetson no problem and they all build and run fine.. XDisplay is opened with no issue, I can even build them from VisualGDB, and execute them, but when run any attempt to open an Xwindow on Ubuntu 18.04 fails…. This is only happening when I try to run from VisualGDB actually running them from a terminal on the target, they run fine. So there has to be something going wrong somewhere? I accept you are only sending a request for forwarding but is there anything else that needs to be set on Ubuntu? Or something that would corrupt that request?
This reply was modified 6 years, 9 months ago by
Brian Beuken.
June 6, 2019 at 00:58 #25079support
KeymasterPlease check if the problem also happens when using other SSH clients (e.g. PuTTY).
June 6, 2019 at 01:14 #25082Brian Beuken
ParticipantI’ll install putty, but can you walk me through what you want me to do? Just navigaing to the directory and using ./ gives a segmentation fault, so I assume that also means that it was unable to get a display?
Is there something else I should do?
June 6, 2019 at 01:21 #25083support
KeymasterIf running the program directly results in a segmentation fault, the device configuration might be corrupt. Unfortunately, as this is not something controlled by VisualGDB, this is not covered by our technical support.
June 6, 2019 at 01:27 #25084Brian Beuken
Participantok I’ll keep trying and report back if I find a solution, but it really is troubling this has happened on a few Ubuntu systems and means I can’t use VisualGDB on those systems. Until this is resolved.
June 6, 2019 at 01:32 #25085support
KeymasterIf you can confirm that the problem doesn’t happen when running the program manually, but does happen with VisualGDB, we can help you understand the differences and configure VisualGDB to replicate the working setup. If the problem also happens without VisualGDB (or if another problem is preventing the programs from running on that target), unfortunately this is not something that could be easily fixed by VisualGDB and hence is not covered by our support, sorry.
June 6, 2019 at 01:47 #25086Brian Beuken
ParticipantIf I open a terminal on the Jetson itself, navigate to the tmp\VisualGDB\c…etc folder
and ./runnablebuild
it runs perfectly, of course its running stand alone
If I use VisualGDB I get no X11 display and project fails trying to use a NULL pointer I added a Fail output on no display, and exit
If I use VisualGDB’s SSH manager and a SmarTTY console, I get the same fail
If I use Putty to navigate to the folder and do ./runnablebuild it also fails for the same reasons and exits
So any attempt to run from SSH seems to fail..
I agree it seems to be an issue with the target, but do you have any tips where I can try to find out why a display cannot be opened. I haveused Xhost +, ensured X11Forward is set
Thats as much info as I can locate onlineJune 6, 2019 at 02:13 #25087support
KeymasterSorry, the only way we can manage the large amount of inquiries we receive and ensure fast turnaround for VisualGDB fixes is by being upfront and strict about the scope of our technical support. Troubleshooting Linux configuration issues can be tricky and there are numerous online resources that could help with that, but unfortunately it is not realistic for us to offer this type of help as a part of our regular product support.
June 6, 2019 at 16:12 #25088Brian Beuken
ParticipantOk I’ll update you if I make progress.I noted the issue on Nvidias forums as well, so given that lots of people are doing graphic work on these boards someone must be also using an ssh connection to develop.
June 7, 2019 at 21:37 #25100Brian Beuken
Participantfound it.
I figured it had to be something to do with access rights somewhere, so I went to the settings and checked the Securty and Privacy->Password settings. I didn’t see anything odd there, but while I was in I switched to autolog on.
Guess what.. that solves it.. My projects now happily build and run and can be executed from my VisualGDB debug command.
To double check I set autologin back to off and sure enough my VisualGDB failed again
So the secret is… ensure you have automatic login, with your matching ssh username
Bizzare issue…Dunno why this is happening, but very happy I resolved it.
If anyone else is using an Ubuntu 18.04 system and fails to get an Xwindow to open, this may be the cause.
