Windows 7 64 bit explorer crashes
Sysprogs forums Forums WinCDEmu Windows 7 64 bit explorer crashes
  • #683
    sepetci
    WinCdEmu continuously crashes on Windows 7 Ultimate 64 bit; during start up and onwards. I ended up unwillingly uninstalling wincdemu πŸ™
    As far as I understand it is about WinCDEmuContextMenu.dll..
    Faulting application name: Explorer.EXE, version: 6.1.7600.16450, time stamp: 0x4aebab8d
    Faulting module name: WinCDEmuContextMenu.dll_unloaded, version: 0.0.0.0, time stamp: 0x4e4026cb
    Exception code: 0xc0000005
    Fault offset: 0x000007fef8c4fdcc
    Faulting process id: 0x958
    Faulting application start time: 0x01cee2d13609a207
    Faulting application path: C:WindowsExplorer.EXE
    Faulting module path: WinCDEmuContextMenu.dll
    Any workarounds for this problem?
    Thanks in advance..
    #2778
    No solution because that file is for context menu and you can’t avoid the installation ( why the author has choice a .dll instead of a simply registry entry? )
    Use the portable version, don’t have that .dll
    #2779
    sepetci
    Thanks for the info.
    I’ve tried the portable one and it works πŸ’‘
    Best regards.
