WincdEmu is causing Windows Explorer to crash
Sysprogs forums Forums WinCDEmu WincdEmu is causing Windows Explorer to crash
  • #364
    yanglifu90
    I used Shelxview to filter non-Microsoft shell extension to find out WinCDEmu is causing Windows Explorer to stop working, anyone has a similar problem? 😳
    #1986
    VGA
    Weird. Which version and on which OS ?
    Uninstall and reinstall last version as admin. :geek:
    #1987
    Yes! I have this problem too, it’s very annoying!
    Faulting application name: Explorer.EXE, version: 6.1.7601.17567, time stamp: 0x4d6727a7
    Faulting module name: mydocs.dll_unloaded, version: 0.0.0.0, time stamp: 0x4ce7b8fb
    Exception code: 0xc0000005
    Fault offset: 0x6d77eb75
    Faulting process id: 0x12cc
    Faulting application start time: 0x01cc9cc27abf117e
    Faulting application path: C:WindowsExplorer.EXE
    Faulting module path: mydocs.dll
    Report Id: 21f1374c-08b7-11e1-b2e3-00241d902f92
    #1985
    yanglifu90
    It happens on both Windows 7 and Windows Thin PC.
    #1988
    sepetci
    same here in window7 ultimate 64 bit.. it frequently crashes even not in use and (as far as i understand) it is about WinCDEmuContextMenu.dll. i ended up uninstalling wincdemu πŸ™
    if there is a solution for this please let us know; i want to use wincdemu since it is much more practical than any other auto-mount software that I’ve ever used.
    log is here:
    Faulting application name: Explorer.EXE, version: 6.1.7600.16450, time stamp: 0x4aebab8d
    Faulting module name: WinCDEmuContextMenu.dll_unloaded, version: 0.0.0.0, time stamp: 0x4e4026cb
    Fault offset: 0x000007fef8c4fdcc
    Faulting process id: 0x958
    Faulting application start time: 0x01cee2d13609a207
    Faulting module path: WinCDEmuContextMenu.dll
