Sysprogs forums › Forums › WinCDEmu › WinCDEmu causes BSOD when Driver Verifier is active
- This topic has 3 replies, 3 voices, and was last updated 13 years, 7 months ago by
homer32.
December 11, 2011 at 18:56 #380
VulcanTourist
ParticipantTwo reboots, two BSODs, after which I booted into safe mode and uninstalled WinCDEmu:
On Sun 2011-12-11 6:20:58 PM GMT your computer crashed
crash dump file: C:WindowsMinidump121111-145892-01.dmp
This was probably caused by the following module: bazisvirtualcdbus.sys (BazisVirtualCDBus+0x137CB)
Bugcheck code: 0xC9 (0x215, 0xFFFFF880055A77CB, 0xFFFFF98005910E10, 0x0)
Error: DRIVER_VERIFIER_IOMANAGER_VIOLATION
file path: C:Windowssystem32driversbazisvirtualcdbus.sys
product: WinCDEmu
company: SysProgs.org
description: WinCDEmu virtual CDROM bus
Bug check description: This is the bug check code for all Driver Verifier
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bazisvirtualcdbus.sys (WinCDEmu virtual CDROM bus, SysProgs.org).
Google query: bazisvirtualcdbus.sys SysProgs.org DRIVER_VERIFIER_IOMANAGER_VIOLATIONOn Sun 2011-12-11 6:20:58 PM GMT your computer crashed
crash dump file: C:Windowsmemory.dmp
product: WinCDEmu
Google query: bazisvirtualcdbus.sys SysProgs.org DRIVER_VERIFIER_IOMANAGER_VIOLATIONThis was version 3.6. I activated Driver Verifier because I was encountering BSODs at various times that pointed to other suspects. Driver Verifier apparently brought out some unexpected bad behavior in WinCDEmu. Whether WinCDEmu was actually the proximal cause of the other BSODs remains to be seen.
December 26, 2011 at 12:12 #2002VulcanTourist
ParticipantNot a peep, no acknowledgement? It was my understanding that when Driver Verifier flags a driver in this fashion that it means there *is* a problem that needs to be fixed. Is that disputed?
January 3, 2012 at 15:35 #2003claushviid
ParticipantI have exactly the same problem(Win7 64 bit)
August 3, 2012 at 22:22 #2004homer32
product: WinCDEmu
product: WinCDEmu
mine is also 3.6 and I am having the same problem and I have wasted so much time with this, did you find a solution?
