Real-time variables are included in the Custom edition of VisualGDB and higher. If you are using a lower edition, you can upgrade it here: http://visualgdb.com/buy/
If you are using VisualGDB Custom, please share a screenshot of the Help->About VisualGDB window and a screenshot of the Visual Studio window with the Debug->Windows menu open and the VisualGDB-based items missing and we will help you get them to appear.
“visual studio has detected that an operation is blocking user input. This can be caused by an active modal dialog or a task that needs to block user interation. Would you
like to shut down anyway ?”
This issue I got once I put the 2 code base in debug mode. Could you please suggest me the resolution for that.
Please try obtaining the call stack of the main Visual Studio’s thread as shown here: http://visualgdb.com/support/callstack and share it in this thread along with the VisualGDB build number. This should explain what is going on.
