VS 2015 Builds slow way down, Clang stops working
Sysprogs forums › Forums › VisualGDB › VS 2015 Builds slow way down, Clang stops working
  • #11020
    andybraham
    I just purchased the VisualGDB for Visual Studio and everything started working alright however after working on the code for a while the builds will slow way down. Almost to the point where it is taking almost 30 seconds per file. The only thing that seems to remedy this is rebooting the entire computer. Another thing that happens when Visual Studio starts to slow down is Clang will stop working all together, I can’t even get it to come up manually by pressing Ctrl+Space. I am working on a BeagleBone-Debian project if that makes any sense. I am not sure what to even try with this, hopefully someone has ran into this before and has a simple fix for me.
    OS: Windows 10 Pro
    VisualGDB: 5.2R9
    Thanks!
    #11021
    If both building and IntelliSense is slow, perhaps something is using the CPU? Could you please check the CPU usage via Task Manager? This could also happen if the RAM utilization was too high or too much background disk activity was slowing down the access to the source files.
