VisualGDB V5.2
Sysprogs forums Forums VisualGDB VisualGDB V5.2
  • #9469
    Spyy
    since i bought VisualGDB and use it with mbed i have problems:
    1. I can’t add resources to my project via import. The import option is not in the menu anymore when i right click on the source file folder.
    2. When i start with a simple project (the LED blink) and i compile it i get 768 warnings “1><command-line> : warning :  “MBED_CONF_NORDIC_UART_HWFC” redefined 1>  <command-line>(0): note :  this is the location of the previous definition
    I am using Visual Studio 2015 with the mbed LCP1768…
    Thank you
    Torsten
    #9471
    The “import folder recursively” feature is available starting from the Custom edition. You can always upgrade your VisualGDB here: https://sysprogs.com/splm/mykey
    Regarding MBED_CONF_NORDIC_UART_HWFC, it’s a known issue of the current mbed 5.2 beta BSP. It can be safely ignored and will be resolved in the final release.
