Sysprogs forums › Forums › VisualGDB › VisualGDB test error.
- This topic has 3 replies, 2 voices, and was last updated 11 years, 8 months ago by
tekati.
July 25, 2014 at 00:28 #872
tekati
ParticipantI installed VisualGDB into Visual Studio 2013.
Ran through this tutorial: http://visualgdb.com/tutorials/raspberry/Trying to rebuild test program I get this build log.
Build started 7/24/2014 5:23:02 PM. 1>Project "F:UsersrobertDropboxSourcePiTestPiTestPiTestPi.vcxproj" on node 2 (Rebuild target(s)).
1>Rebuild:
"C:Program Files (x86)SysprogsVisualGDBVisualGDB.exe" /rebuild "F:UsersrobertDropboxSourcePiTestPiTestPiTestPi.vcxproj" "/solution:F:UsersrobertDropboxSourcePiTestPiTestPi.sln" "/config:Debug" "/platform:Win32"
VisualGDB: Attempting inline build...
VisualGDB: Run "make CONFIG=Debug clean" in directory "/tmp/VisualGDB/f/Users/robert/Dropbox/Source/Pi/TestPi/TestPi" on pro@192.168.1.180 (SSH)
make: *** No rule to make target `clean'. Stop. Command exited with code 2
Executable: make
Arguments: CONFIG=Debug clean
Directory: /tmp/VisualGDB/f/Users/robert/Dropbox/Source/Pi/TestPi/TestPi
VisualGDB: Updated source file list in F:UsersrobertDropboxSourcePiTestPiTestPiMakefile. Enable verbose mode for more details.
VisualGDB: Sending 6 updated source files to build machine...
VisualGDB: Run "make CONFIG=Debug" in directory "/tmp/VisualGDB/f/Users/robert/Dropbox/Source/Pi/TestPi/TestPi" on pro@192.168.1.180 (SSH)
mkdir Debug
g++ -ggdb -ffunction-sections -O0 -DDEBUG -c TestPi.cpp -o Debug/TestPi.o -MD -MF Debug/TestPi.dep
g++ -o Debug/TestPi -Wl,-gc-sections -Wl,--start-group Debug/TestPi.o -Wl,--rpath='$ORIGIN' -Wl,--end-group
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0V120Microsoft.MakeFile.Targets(43,5): error MSB3073: The command ""C:Program Files (x86)SysprogsVisualGDBVisualGDB.exe" /rebuild "F:UsersrobertDropboxSourcePiTestPiTestPiTestPi.vcxproj" "/solution:F:UsersrobertDropboxSourcePiTestPiTestPi.sln" "/config:Debug" "/platform:Win32"" exited with code -1.
1>Done Building Project "F:UsersrobertDropboxSourcePiTestPiTestPiTestPi.vcxproj" (Rebuild target(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:00:08.94
Tried closing Visual Studio 2013 no luck. Was getting error 9009 until then.
July 26, 2014 at 02:23 #3287support
Based on the log, the clean action fails because there is no project built yet (it should be normally ignored), but the build succeeds. Does the normal build command (not rebuild) work?July 26, 2014 at 22:29 #3288tekati
Participant@bazis wrote:
Based on the log, the clean action fails because there is no project built yet (it should be normally ignored), but the build succeeds. Does the normal build command (not rebuild) work?You are right it does build. It threw me because I am showing 100 intellisense errors. Any idea why I am getting a ton of errors?
August 3, 2014 at 16:53 #3286support
VisualGDB supports IntelliSense by providing configuration and compatibility definitions to the Visual Studio IntelliSense engine. However, some GCC-specific constructs still confuse it and cause false positives. We are currently developing an independent clang-based IntelliSense engine that will solve that problem. As a temporary workaround, you can right-click on the errors window and disable IntelliSense errors completely.
