Sysprogs forums › Forums › VisualGDB › VisualGDB Python file import problems when debug
- This topic has 2 replies, 2 voices, and was last updated 6 years, 10 months ago by
julienmercenier.
April 3, 2019 at 13:33 #24555
julienmercenier
When debugging, I can’t import a python file “Test_CommonFunctions.py” (code : from Test_CommonFunctions import *) even if it is located in the same directory than the script that is run.
When running the same code directly on the target using command “python Test.py”, while having CommonFunctions.py in the same directory than Test.py, there is no problem.
This is quite a problem if I do not want to have code duplication.
VisualGDB version: 5.4.104.3031
Best regards,
Julien
<hr />
VisualGdb Program Output:
&”warning: GDB: Failed to set controlling terminal: Operation not permitted\n”
Traceback (most recent call last):
File “/tmp/com_sysprogs_PythonDebugWrapper.py”, line 97, in <module>
com_sysprogs_PythonDebugHelper.Initialize()
File “/tmp/com_sysprogs_PythonDebugWrapper.py”, line 95, in Initialize
inst.Launch()
File “/tmp/com_sysprogs_PythonDebugWrapper.py”, line 89, in Launch
runpy.run_path(self.DebuggedScript)
File “/usr/lib/python2.7/runpy.py”, line 252, in run_path
return _run_module_code(code, init_globals, run_name, path_name)
File “/usr/lib/python2.7/runpy.py”, line 82, in _run_module_code
mod_name, mod_fname, mod_loader, pkg_name)
File “/usr/lib/python2.7/runpy.py”, line 72, in _run_code
exec code in run_globals
File “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/../Scripts/Test_AcquisitionDelay.py”, line 4, in <module>
ImportError: No module named Test_CommonFunctions<hr />
VisualGDB Diagnostics
SSH [81]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -d “/tmp/VisualGDB/c/Local/PRO/DT777/MSML/MSML”
SSH [81]: command exited with code 0 after 20 msec
SSH [82]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/MSML/MSML” && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && “make” CONFIG=Debug
SSH [82]: command exited with code 0 after 31 msec
No deployment host specified for /tmp/VisualGDB/c/Local/PRO/DT777/MSML/MSML/Debug/MSML.so. Skipping…
SSH [83]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -d “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt”
SSH [83]: command exited with code 0 after 13 msec
SSH [84]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt” && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && “make” CONFIG=Debug
SSH [84]: command exited with code 0 after 61 msec
ShouldRedirectToVisualGDBImpl(): C:\Local\PRO\DT777\Tests\MSML_PyExt\MSML_PyExt-Debug.vgdbsettings
Searching for active configuration for MSML_PyExt\MSML_PyExt.vcxproj…
Trying fast lookup…
Found! Configuration name = Debug
Trying fast lookup…
Searching for active configuration for ..\MSML\MSML\MSML.vcxproj…
Trying fast lookup…
Locating deployed dependencies for project…
SSH [85]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -f “/tmp/com_sysprogs_PythonBreakpointModule.so”
SSH [85]: command exited with code 0 after 16 msec
SSH [86]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -f “/tmp/com_sysprogs_PythonDebugWrapper.py”
SSH [86]: command exited with code 0 after 12 msec
SSH [87]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/Debug” && stty -echo && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && export PYTHONPATH=”${PYTHONPATH}:/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/Debug” && “gdb” –interpreter mi –args “python” “/tmp/com_sysprogs_PythonDebugWrapper.py” “/tmp/com_sysprogs_PythonBreakpointModule.so” /tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/../Scripts/Test_AcquisitionDelay.py
Creating a temporary SSH console…
Requesting a temporary console: tty && sleep 2147483647
Trying fast lookup…
[+589265] GDB stop event received
[+259] GDB stop event received
SSH [87]: command exited with code 0 after 1833 msec
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
SSH [88]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -d “/tmp/VisualGDB/c/Local/PRO/DT777/MSML/MSML”
SSH [88]: command exited with code 0 after 29 msec
SSH [89]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/MSML/MSML” && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && “make” CONFIG=Debug
SSH [89]: command exited with code 0 after 42 msec
SSH [90]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -d “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt”
SSH [90]: command exited with code 0 after 19 msec
SSH [91]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt” && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && “make” CONFIG=Debug
SSH [91]: command exited with code 0 after 47 msec
Trying fast lookup…
Trying fast lookup…
Trying fast lookup…
SSH [92]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -f “/tmp/com_sysprogs_PythonBreakpointModule.so”
SSH [92]: command exited with code 0 after 21 msec
SSH [93]: executing command: export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && “test” -f “/tmp/com_sysprogs_PythonDebugWrapper.py”
SSH [93]: command exited with code 0 after 15 msec
SSH [94]: executing command: cd “/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/Debug” && stty -echo && export PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” && export QT_QPA_PLATFORMTHEME=”appmenu-qt5″ && export XDG_DATA_DIRS=”/usr/local/share:/usr/share:/var/lib/snapd/desktop” && export LANG=”en_US.UTF-8″ && export PYTHONPATH=”${PYTHONPATH}:/tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/Debug” && “gdb” –interpreter mi –args “python” “/tmp/com_sysprogs_PythonDebugWrapper.py” “/tmp/com_sysprogs_PythonBreakpointModule.so” /tmp/VisualGDB/c/Local/PRO/DT777/Tests/MSML_PyExt/../Scripts/Test_AcquisitionDelay.py
Trying fast lookup…
[+43007] GDB stop event received
[+249] GDB stop event received
SSH [94]: command exited with code 0 after 1768 msec<hr />
GDB session : see attach
You must be logged in to view attached files.April 3, 2019 at 21:01 #24566support
Please try setting the PYTHONPATH variable to point to the directory on the board where the Python scripts are uploaded. You can set it via VisualGDB Project Properties ->Debug Settings -> Common Settings -> Debug Mode -> Additional Environment. This should ensure Python can find import all the necessary modules.
April 26, 2019 at 10:14 #24811julienmercenier
ParticipantThank you for the help,
This solved my problem.
BR,
Julien
