VisualGDB Preview 5.5 IAR Support
Sysprogs forums › Forums › VisualGDB › VisualGDB Preview 5.5 IAR Support
  • #26284
    dan5912
    I have downloaded and installed 5.5 preview with “IAR Support”, selected IAR compiler in the build wizard, but am not given any options to set up the IAR toolchain. Additionally, after I set up the IAR toolchain manually via the mak file, the IAR warnings and errors are still not recognized by the new visualgdb build window. Initial make messages are supported, but I see no support for IAR. Am I missing something? There does not appear to by any tutorial or explanation on this topic despite advertising it as a new feature.
    #26285
    dan5912
    I should clarify that I am importing an IAR project, not creating a new project. Creating new appears to work.
    #26287
    Normally, the IAR should work out-of-the-box and modifying the Makefile should not be necessary.
    Please double-check whether the IAR toolchain appears on the Toolchain Selection page of the VisualGDB Embedded Project wizard:
    • When creating a new project from scratch
    • When trying to import a project
    If the toolchain appears while creating a new project and doesn’t appear while importing it, would you be able to send us the .ewp file so that we could check what is going on?
    #26293
    BTW, we have just updated our IAR tutorial showing the new out-of-the-box integration. Feel free to use it as a reference while troubleshooting IAR-related issues.
    #26561
    joerg
    I`ve just downloaded the Trial Version and I am having the same Problem.
    The IAR toolchain dos not appear for download, neither in creating a new Project nor in importing an existing Project.
    #26565
    Please make sure you use the VisualGDB 5.5 Preview 1, not v5.4.
    Also you need to install the IAR compiler separately, and make sure you have a valid license for it (see this tutorial). We are not affiliated with IAR Systems, so VisualGDB can integrate with an existing IAR installation, but cannot redistribute it independently.
