Sysprogs forums › Forums › VisualGDB › VisualGDB on cocos2d-x
- This topic has 6 replies, 2 voices, and was last updated 12 years, 4 months ago by
ket.
November 20, 2013 at 14:04 #686
alenl
Participantso i’m trying to setup VisualGDB for cocos2d-x (android). I got it to compile, run and break but i can’t get it to read and alter variables i get:
-var-create: unable to create variable objectNovember 20, 2013 at 17:14 #2791ket
Not every part of code you can hover over is a genuine variable. We poll the gdb always to ask whether it is a variable and then show the variable’s information if applicable. Please try the Autos and Locals windows to see all the current variables listed or enter them to the Watch window.
If genuine variables are still not shown, then please give us a full GDB log showing all the GDB interaction. For this enable diagnostic GDB logging on the GDB settings page in VisualGDB Project Properties. Then start debugging and replicate your scenario. Finally stop debugging and send us the resulting log file from your project directory.
November 20, 2013 at 19:10 #2792alenl
ParticipantIt is a “real” varibable thats for sure
void cocos_android_app_init (struct android_app* app) { sleep(3); int iWantToReadYou = 123; LOGD("NUM %d",iWantToReadYou); LOGD("cocos_android_app_init"); AppDelegate *pAppDelegate = new AppDelegate(); }Im adding this argument for ndk-build
NDK_MODULE_PATH=E:/mobilesvn/Wacky/cocos2d-x;E:/mobilesvn/Wacky/cocos2d-x/external;E:/mobilesvn/Wacky/cocos2d-x/cocosi noticed that the console was giving me this:
No symbol "disassembly" in current context. No symbol table is loaded. Use the "file" command.I allso looked at the log file and found this
~"Reading symbols from C:/Users/Alen/AppData/Local/VisualGDB/AndroidBinaryCache/01bf1190e24af3cc/app_process..." ~"done.n" ~"n" ~"WARNING: no debugging symbols found in C:/Users/Alen/AppData/Local/VisualGDB/AndroidBinaryCache/01bf1190e24af3cc/app_process.n" ~"Either the binary was compiled without debugging informationnor the debugging information was removed (e.g., with strip or strip -g).nDebugger capabilities will be very limited.n" ~"For further information: http://wiki/Main/GdbFaq#No_debugging_symbols_foundn" ~"n"My Android.mk
LOCAL_PATH := $(call my-dir) include $(CLEAR_VARS) LOCAL_MODULE := cocos2dcpp_shared LOCAL_MODULE_FILENAME := libcocos2dcpp #VisualGDBAndroid: AutoUpdateSourcesInNextLine LOCAL_SRC_FILES := ../../Classes/AppDelegate.cpp ../../Classes/HelloWorldScene.cpp hellocpp/main.cpp LOCAL_C_INCLUDES := $(LOCAL_PATH)/../../Classes LOCAL_WHOLE_STATIC_LIBRARIES := cocos2dx_static LOCAL_WHOLE_STATIC_LIBRARIES += spine_static LOCAL_WHOLE_STATIC_LIBRARIES += cocosdenshion_static include $(BUILD_SHARED_LIBRARY) $(call import-module,2d) $(call import-module,audio/android) $(call import-module,editor-support/spine)And Application.mk
APP_STL := gnustl_static APP_CPPFLAGS := -frtti -DCC_ENABLE_CHIPMUNK_INTEGRATION=1 -DCOCOS2D_DEBUG=1 -std=c++11 -fsigned-char NDK_TOOLCHAIN_VERSION := 4.8 APP_ABI := armeabi-v7aSo i guess that i dident get debug symbols at all
November 20, 2013 at 20:58 #2793alenl
ParticipantOk so after many trys i got it to work.
All i needed to to is change my toolchain version.
NDK_TOOLCHAIN_VERSION := clang3.3But i still dont understand why that is?
November 21, 2013 at 03:04 #2794ket
Based on the log, the symbols are loaded. The early errors in the log about symbols not being loaded are before gdb even connects to the Android device and loads the symbols. Based on the log you should also be able to see the call stack, threads and step through code. The gdb does reply that it cannot create the variable iWantToReadYou, that happens when it does not know of any variable with that name.
It could be that the code was optimized and that iWantToReadYou was optimized out. As clang is a completely different compiler from gcc, it does compilation and optimization differently. Try adding V=1 to the ndk-build arguments and post the gcc command line from the build output in the Output window here. Also is iWantToReadYou the only variable not shown i.e. are there any variables shown in the Locals and Autos windows?
November 21, 2013 at 08:02 #2795alenl
ParticipantHi
So i can break see call stack and all that i can allso read all my global variables with 4.8 like so
(file main.cpp)
int thisOneWorks = 321; void cocos_android_app_init (struct android_app* app) { sleep(3);//WAIT FOR GDB int iWantToReadYou = 123; LOGD("NUM %d",iWantToReadYou); //<- i break here where i can get 'thisOneWorks ' but not 'iWantToReadYou' LOGD("cocos_android_app_init"); AppDelegate *pAppDelegate = new AppDelegate(); }Autos window will give me:
cocos_android_app_init 0x73759c4c <_z22cocos_android_app_initp11android_app>
sleep 0x4014c646
And Locals gives me:
+ cocos2d::PHYSICSSHAPE_MATERIAL_DEFAULT {density = 0, restitution = 0.5, friction = 0.5} const cocos2d::PhysicsMaterial cocos2d::kCCPriorityNonSystemMin -2147483647 const int + cocos2d::PHYSICSBODY_MATERIAL_DEFAULT {density = 0.100000001, restitution = 0.5, ...} const cocos2d::PhysicsMaterial + std::__ioinit {_S_refcount = 23, _S_synced_with_stdio = true} std::ios_base::Init cocos2d::kCCPrioritySystem -2147483648 const int thisOneWorks 321 intNovember 27, 2013 at 06:43 #2796ket
Based on the fact that some variables even from the same file have readable values, it is highly likely that the compiler has somehow optimized the iWantToReadYou variable out. Based on the build log however, there are no unusual flags passed to g++. There are the additional flags that cocos2dx needs, but none of them should affect optimization. It could be a compiler bug to still perform some optimization.
If you wish to look further into it, look into the so file using objdump. Find the correct objdump.exe for your toolchain in your Android NDK installation directory and call objdump from cmd as follows:
--dwarf lib > 0 Then open the 0 file with a text editor and search for iWantToReadYou.
