VisualGDB is unable to connect to the debugee
Sysprogs forums Forums VisualGDB VisualGDB is unable to connect to the debugee
  • #921
    Nadav
    I am trying to Lunch & Debug ( F5 ) a command-line tool with VisualGDB ( UNSUCCESSFULLY)
    While “adb.exe” successfully connects to my device while tring to debug I get “Finished with 0x8000c062” with a popup saying: “Debugging exited without any breakpoint hits”, DBG Log follows:
    Your VisualGDB trial expires in 26 days!
    D:DevelopAndroidandroid-ndk-r10ctoolchainsarm-linux-androideabi-4.8prebuiltwindows-x86_64binarm-linux-androideabi-gdb.exe --interpreter mi "D:DevelopOTTRemoteControlAndroidDeviceScreenCapSvcobjlocalarmeabi-v7aScreenCapSvc" -x "D:DevelopOTTRemoteControlAndroidDeviceScreenCapSvclibsarmeabi-v7agdb.setup"
    =thread-group-added,id="i1"
    GNU gdb (GDB) 7.6
    Copyright (C) 2013 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later
    There is NO WARRANTY, to the extent permitted by law. Type "show copying"
    and "show warranty" for details.
    This GDB was configured as "--host=x86_64-w64-mingw32 --target=arm-linux-androideabi".
    Reading symbols from D:DevelopOTTRemoteControlAndroidDeviceScreenCapSvcobjlocalarmeabi-v7aScreenCapSvc...
    -list-features
    done.
    =cmd-param-changed,param="solib-search-path",value="./obj/local/armeabi-v7a"
    ^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","python"]
    OK
    No symbol "disassembly" in current context.
    -gdb-set print demangle off
    OK
    -gdb-version
    GNU gdb (GDB) 7.6
    OK
    -break-insert -f main
    ^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00009688",func="main(int, char**)",file="jni/ScreenCapSvc.cpp",fullname="D:\Develop\OTT\RemoteControl\Android\Device\ScreenCapSvc\jni\ScreenCapSvc.cpp",line="32",thread-groups=["i1"],times="0",original-location="main"}
    -gdb-set solib-search-path C:/Users/no1/AppData/Local/VisualGDB/AndroidBinaryCache/6680985a;D:/Develop/OTT/RemoteControl/Android/Device/ScreenCapSvc/obj/local/armeabi-v7a
    OK
    -target-select remote :5039
    =thread-group-started,id="i1",pid="12133"
    =thread-created,id="1",group-id="i1"
    =library-loaded,id="/system/bin/linker",target-name="/system/bin/linker",host-name="C:\Users\no1\AppData\Local\VisualGDB\AndroidBinaryCache\6680985a\linker",symbols-loaded="0",thread-group="i1"
    *stopped,frame={addr="0xb6f4aa60",func="_start",args=[],from="C:\Users\no1\AppData\Local\VisualGDB\AndroidBinaryCache\6680985a\linker"},thread-id="1",stopped-threads="all",core="0"
    ^connected
    -break-list
    ^done,BreakpointTable={nr_rows="1",nr_cols="6",hdr=[{width="7",alignment="-1",col_name="number",colhdr="Num"},{width="14",alignment="-1",col_name="type",colhdr="Type"},{width="4",alignment="-1",col_name="disp",colhdr="Disp"},{width="3",alignment="-1",col_name="enabled",colhdr="Enb"},{width="10",alignment="-1",col_name="addr",colhdr="Address"},{width="40",alignment="2",col_name="what",colhdr="What"}],body=[bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00009688",func="main(int, char**)",file="jni/ScreenCapSvc.cpp",fullname="D:\Develop\OTT\RemoteControl\Android\Device\ScreenCapSvc\jni\ScreenCapSvc.cpp",line="32",thread-groups=["i1"],times="0",original-location="main"}]}
    info shared
    &"info sharedn"
    From To Syms Read Shared Object Library
    0xb6f4aa60 0xb6f55820 Yes C:Usersno1AppDataLocalVisualGDBAndroidBinaryCache6680985alinker
    OK
    -exec-continue
    ^running
    *running,thread-id="all"
    *stopped,reason="solib-event",thread-id="1",stopped-threads="all",core="0"
    -break-list
    -exec-continue
    ^running
    *running,thread-id="1"
    -break-list
    -exec-continue
    ^running
    -break-list
    -exec-continue
    ^running
    =library-loaded,id="libc.so",target-name="libc.so",host-name="C:\Users\no1\AppData\Local\VisualGDB\AndroidBinaryCache\6680985a\libc.so",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="C:\Users\no1\AppData\Local\VisualGDB\AndroidBinaryCache\6680985a\libc.so"],thread-id="1",stopped-threads="all",core="0"
    -break-list
    info shared
    &"info sharedn"
    0xb6ef1198 0xb6f21bfc Yes C:Usersno1AppDataLocalVisualGDBAndroidBinaryCache6680985alibc.so
    OK
    -exec-continue
    ^running
    -break-list
    -exec-continue
    ^running
    =library-loaded,id="libstdc++.so",target-name="libstdc++.so",host-name="libstdc++.so",symbols-loaded="0",thread-group="i1"
    &"warning: Could not load shared library symbols for libstdc++.so.nDo you need "set solib-search-path" or "set sysroot"?"
    &"n"
    *stopped,reason="solib-event",added=[library="libstdc++.so"],thread-id="1",stopped-threads="all",core="0"
    -break-list
    info shared
    &"info sharedn"
    No libstdc++.so
    OK
    -exec-continue
    ^running
    -break-list
    -exec-continue
    ^running
    =library-loaded,id="libm.so",target-name="libm.so",host-name="libm.so",symbols-loaded="0",thread-group="i1"
    &"warning: Could not load shared library symbols for libm.so.nDo you need "set solib-search-path" or "set sysroot"?"
    &"n"
    *stopped,reason="solib-event",added=[library="libm.so"],thread-id="1",stopped-threads="all",core="0"
    -break-list
    info shared
    &"info sharedn"
    No libstdc++.so
    No libm.so
    OK
    -exec-continue
    ^running
    -break-list
    -exec-continue
    ^running
    =library-loaded,id="liblog.so",target-name="liblog.so",host-name="liblog.so",symbols-loaded="0",thread-group="i1"
    &"warning: Could not load shared library symbols for liblog.so.nDo you need "set solib-search-path" or "set sysroot"?"
    &"n"
    *stopped,reason="solib-event",added=[library="liblog.so"],thread-id="1",stopped-threads="all",core="0"
    -break-list
    info shared
    &"info sharedn"
    No libstdc++.so
    No libm.so
    No liblog.so
    OK
    -exec-continue
    ^running
    =breakpoint-modified,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00009688",func="main(int, char**)",file="jni/ScreenCapSvc.cpp",fullname="D:\\Develop\\OTT\\RemoteControl\\Android\\Device\\ScreenCapSvc\\jni\\ScreenCapSvc.cpp",line="32",thread-groups=["i1"],times="1",original-location="main"}
    *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x00009688",func="main",args=[{name="argc",value="1"},{name="argv",value="0xbecd08c4"}],file="jni/ScreenCapSvc.cpp",fullname="D:\Develop\OTT\RemoteControl\Android\Device\ScreenCapSvc\jni\ScreenCapSvc.cpp",line="32"},thread-id="1",stopped-threads="all",core="0"
    -break-delete 1
    OK
    -exec-continue
    ^running
    =thread-group-exited,id="i1",exit-code="0"
    *stopped,reason="exited-normally"
    How can I make debugging work ?
    #3444
    From the GDB perspective, the breakpoints are set correctly, but the tool simply exits. Are you missing custom LD_LIBRARY_PATH? Does the tool run normally when you launch it manually? Do you experience the same issues with a basic “Hello, World” tool?
    #3441
    Nadav
    The problem was due to a bug in my code, however, the strange thing is that my code has exited ( as it should have ) although breakpoints that should have been stepped by GDB were simply ignored…
    #3442
    That depends on the bug. If your bug caused an exception during program initialization (before main() got a chance to run), the breakpoints would not be triggered.
    #3443
    overthis
    I’m not sure If my problem is the same or not, but my breakpoints do not get caught / triggered / w/e.
    To my knowledge my program runs and exits properly. Any ideas? If it was something like an exception being thrown before initialization, how could I check that? I’ve never encountered this issue before.
    Thanks for your time.
    VisualGDB is licensed to *************
    C:UsersoverthisDropboxResearchcygwin64bingdb.exe --interpreter mi --args "C:UsersoverthisDropboxResearchcygwin64homeoverthisNetsimcmeshtestncmesh.exe" 4 0 1 1 100 9 1 100 0
    -list-features
    GNU gdb (GDB) 7.6.50.20130728-cvs (cygwin-special)
    This GDB was configured as "x86_64-pc-cygwin".
    Type "show configuration" for configuration details.
    For help, type "help".
    Type "apropos word" to search for commands related to "word".
    Reading symbols from /home/overthis/Netsim/cmesh/testn/cmesh.exe...
    done.
    ^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info"]
    OK
    -data-list-register-names
    ^done,register-names=["rax","rbx","rcx","rdx","rsi","rdi","rbp","rsp","r8","r9","r10","r11","r12","r13","r14","r15","rip","eflags","cs","ss","ds","es","fs","gs","st0","st1","st2","st3","st4","st5","st6","st7","fctrl","fstat","ftag","fiseg","fioff","foseg","fooff","fop","xmm0","xmm1","xmm2","xmm3","xmm4","xmm5","xmm6","xmm7","xmm8","xmm9","xmm10","xmm11","xmm12","xmm13","xmm14","xmm15","mxcsr","","","","","","","","","","","","","","","","","al","bl","cl","dl","sil","dil","bpl","spl","r8l","r9l","r10l","r11l","r12l","r13l","r14l","r15l","ah","bh","ch","dh","ax","bx","cx","dx","si","di","bp","","r8w","r9w","r10w","r11w","r12w","r13w","r14w","r15w","eax","ebx","ecx","edx","esi","edi","ebp","esp","r8d","r9d","r10d","r11d","r12d","r13d","r14d","r15d"]
    OK
    OK
    -gdb-version
    OK
    ^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x0000000100407e80",func="main",file="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",fullname="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",line="63",thread-groups=["i1"],times="0",original-location="main"}
    -gdb-set new-console on
    OK
    info target
    &"info targetn"
    Symbols from "/home/overthis/Netsim/cmesh/testn/cmesh.exe".
    Local exec file:
    `/home/overthis/Netsim/cmesh/testn/cmesh.exe', file type pei-x86-64.
    Entry point: 0x100401000
    0x0000000100401000 - 0x000000010041b108 is .text
    0x000000010041c000 - 0x000000010041c2e8 is .data
    0x000000010041d000 - 0x0000000100421740 is .rdata
    0x0000000100422000 - 0x0000000100422c00 is .pdata
    0x0000000100423000 - 0x0000000100423bac is .xdata
    0x0000000100424000 - 0x0000000101739bd0 is .bss
    0x000000010173a000 - 0x000000010173a75c is .idata
    0x000000010173b000 - 0x000000010173b460 is .rsrc
    OK
    -exec-run
    =thread-group-started,id="i1",pid="1352"
    [New Thread 1352.0x14ac]
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/ntdll.dll",target-name="/cygdrive/c/Windows/system32/ntdll.dll",host-name="/cygdrive/c/Windows/system32/ntdll.dll",symbols-loaded="0",thread-group="i1"
    =library-loaded,id="/cygdrive/c/Windows/system32/kernel32.dll",target-name="/cygdrive/c/Windows/system32/kernel32.dll",host-name="/cygdrive/c/Windows/system32/kernel32.dll",symbols-loaded="0",thread-group="i1"
    =library-loaded,id="/cygdrive/c/Windows/system32/KERNELBASE.dll",target-name="/cygdrive/c/Windows/system32/KERNELBASE.dll",host-name="/cygdrive/c/Windows/system32/KERNELBASE.dll",symbols-loaded="0",thread-group="i1"
    =library-loaded,id="/usr/bin/cygwin1.dll",target-name="/usr/bin/cygwin1.dll",host-name="/usr/bin/cygwin1.dll",symbols-loaded="0",thread-group="i1"
    =thread-created,id="2",group-id="i1"
    [New Thread 1352.0x1e18]
    =library-loaded,id="/cygdrive/c/Windows/system32/user32.dll",target-name="/cygdrive/c/Windows/system32/user32.dll",host-name="/cygdrive/c/Windows/system32/user32.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/user32.dll"],thread-id="1",stopped-threads="all"
    -break-list
    ^done,BreakpointTable={nr_rows="1",nr_cols="6",hdr=[{width="7",alignment="-1",col_name="number",colhdr="Num"},{width="14",alignment="-1",col_name="type",colhdr="Type"},{width="4",alignment="-1",col_name="disp",colhdr="Disp"},{width="3",alignment="-1",col_name="enabled",colhdr="Enb"},{width="18",alignment="-1",col_name="addr",colhdr="Address"},{width="40",alignment="2",col_name="what",colhdr="What"}],body=[bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x0000000100407e80",func="main",file="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",fullname="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",line="63",thread-groups=["i1"],times="0",original-location="main"}]}
    info shared
    &"info sharedn"
    0x0000000077891000 0x0000000077a384e0 Yes /cygdrive/c/Windows/system32/ntdll.dll
    0x0000000077771000 0x000000007788eab8 Yes /cygdrive/c/Windows/system32/kernel32.dll
    0x000007fefd6d1000 0x000007fefd73b13c Yes /cygdrive/c/Windows/system32/KERNELBASE.dll
    0x0000000180041000 0x00000001805e0000 Yes /usr/bin/cygwin1.dll
    0x0000000077671000 0x0000000077769348 Yes /cygdrive/c/Windows/system32/user32.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/GDI32.dll",target-name="/cygdrive/c/Windows/system32/GDI32.dll",host-name="/cygdrive/c/Windows/system32/GDI32.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/GDI32.dll"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007feff351000 0x000007feff3b6210 Yes /cygdrive/c/Windows/system32/GDI32.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/LPK.dll",target-name="/cygdrive/c/Windows/system32/LPK.dll",host-name="/cygdrive/c/Windows/system32/LPK.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/LPK.dll"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007feff0d1000 0x000007feff0dd034 Yes /cygdrive/c/Windows/system32/LPK.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/USP10.dll",target-name="/cygdrive/c/Windows/system32/USP10.dll",host-name="/cygdrive/c/Windows/system32/USP10.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/USP10.dll"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007fefdcd1000 0x000007fefdd98278 Yes /cygdrive/c/Windows/system32/USP10.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/msvcrt.dll",target-name="/cygdrive/c/Windows/system32/msvcrt.dll",host-name="/cygdrive/c/Windows/system32/msvcrt.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/msvcrt.dll"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007fefe031000 0x000007fefe0ce4bc Yes /cygdrive/c/Windows/system32/msvcrt.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/IMM32.DLL",target-name="/cygdrive/c/Windows/system32/IMM32.DLL",host-name="/cygdrive/c/Windows/system32/IMM32.DLL",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/IMM32.DLL"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007fefdb21000 0x000007fefdb4d048 Yes /cygdrive/c/Windows/system32/IMM32.DLL
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/MSCTF.dll",target-name="/cygdrive/c/Windows/system32/MSCTF.dll",host-name="/cygdrive/c/Windows/system32/MSCTF.dll",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/MSCTF.dll"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x000007fefdbc1000 0x000007fefdcc8a08 Yes /cygdrive/c/Windows/system32/MSCTF.dll
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/PROGRA~2/Sophos/SOPHOS~1/SOPHOS~2.DLL",target-name="/cygdrive/c/PROGRA~2/Sophos/SOPHOS~1/SOPHOS~2.DLL",host-name="/cygdrive/c/PROGRA~2/Sophos/SOPHOS~1/SOPHOS~2.DLL",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/PROGRA~2/Sophos/SOPHOS~1/SOPHOS~2.DLL"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x0000000075411000 0x0000000075447a38 Yes /cygdrive/c/PROGRA~2/Sophos/SOPHOS~1/SOPHOS~2.DLL
    OK
    -exec-continue
    ^running
    =library-loaded,id="/cygdrive/c/Windows/system32/PSAPI.DLL",target-name="/cygdrive/c/Windows/system32/PSAPI.DLL",host-name="/cygdrive/c/Windows/system32/PSAPI.DLL",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="/cygdrive/c/Windows/system32/PSAPI.DLL"],thread-id="1",stopped-threads="all"
    -break-list
    info shared
    &"info sharedn"
    0x0000000077a51000 0x0000000077a5600c Yes /cygdrive/c/Windows/system32/PSAPI.DLL
    OK
    -exec-continue
    ^running
    =breakpoint-modified,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x0000000100407e80",func="main",file="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",fullname="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",line="63",thread-groups=["i1"],times="1",original-location="main"}
    *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x0000000100407e80",func="main",args=[{name="argc",value="0"},{name="argv",value="0x20000002f"}],file="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",fullname="/cygdrive/c/Users/overthis/Dropbox/Research/cygwin64/home/overthis/Netsim/cmesh/src/driver.c",line="63"},thread-id="1",stopped-threads="all"
    -break-delete 1
    OK
    -exec-continue
    ^running
    =thread-created,id="3",group-id="i1"
    [New Thread 1352.0x1dfc]
    [Thread 1352.0x1dfc exited with code 0]
    =thread-exited,id="3",group-id="i1"
    =thread-exited,id="2",group-id="i1"
    =thread-exited,id="1",group-id="i1"
    #3440
    Your log does not contain any -break-insert commands except for the original breakpoint in main(). Are you sure your breakpoints are enabled?
    #6453
    overthis
    Breakpoints where enabled.
    “Your log does not contain any -break-insert commands except for the original breakpoint in main()”
    This made me realize a parameter on the GDB settings tab was set wrong.
    The “Support ‘step into new instance’ through breakpoint in:’ was set to Main, and should have been UserMain for my project. This fixed my problem.
    • This reply was modified 10 years, 11 months ago by overthis.
