I am trying to create an automated release process and it works almost as intended. The only issue left is that I am having trouble selecting the correct configuration. It seems like VisualGDB.exe is not reading /config and /platform.
Any ideas?
Example:
Visualgdb.exe /build my-project.vgdbproj /config:Release /platform:VisualGDB
VisualGDB: Warning: Project/solution/configuration not specified in command line. Your Makefiles will not be auto-updated. Please go to VisualGDBProject Properties and click ‘repair command lines’.
VisualGDB: Warning: No configuration specified, defaulting to ‘Debug’. Use ‘/config:<name>’ to override.
VisualGDB: Run “C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe ” in directory “c:\build-agent\_work\1\s/VisualGDB/Debug” on local computer
[1/3] Performing build step for ‘bootloader’
ninja: no work to do.
