VisualGDB doesn't link libraries
Sysprogs forums Forums VisualGDB VisualGDB doesn't link libraries
  • #6908
    li0nsar3c00l
    I’m working on a project and tested the code in codeblocks on my raspberry pi 2b (gcc 4.6.3).
    then I created a cross compiler project, synced the proper directories, but when i try to compile, i receive the following error:
    “error VGDB1000: undefined reference to ‘UtilInit()'”
    and some errors regarding the failed build.
    The header files I’m trying to are from the tinycan example, which works on the raspberry itself as I already mentioned.
    Any idea why this fails, besies I added the directories including all the importing files?
    Thanks in advanced
    #6912
    Please try locating the file that defines the UtilInit() function. If it is a C file, ensure that the declaration in the .h file (or the #include<> directive including the .h file) is wrapped with extern “C” {}.
