Sysprogs forums › Forums › VisualGDB › VisualGDB and msbuild
- This topic has 7 replies, 2 voices, and was last updated 8 years, 1 month ago by
February 9, 2018 at 08:06 #20013
KolesnikovAkexandr
ParticipantHi!
Is it possible to somehow configure toolchains from the console? I’m trying to compile a project using but I get an error: error: No toolchain found. Plese configuration of the toolchain via VisualGDB Project Properties.
No opportunity to open in Visual Studio and customize.
February 9, 2018 at 19:05 #20022support
Yes, please try running VisualGDB.exe /pkgmgr
February 12, 2018 at 08:00 #20045KolesnikovAkexandr
ParticipantThanks for your reply! But I need to initialize tolchan only using the console on the remote computer. Your command opens the package manager window
February 12, 2018 at 23:22 #20062support
Sorry, VisualGDB doesn’t provide any console-only commands for managing toolchains (you can install them via the VisualGDB Package Manager though). Please feel free to describe your setup so that we could suggest a better workaround.
February 13, 2018 at 09:34 #20079KolesnikovAkexandr
ParticipantI’m trying to make gitlab ci for a project under stm32. After each commit, the repository on the remote machine is rebooted without the initialized toolchain . The project is built using msbuild
This reply was modified 8 years, 1 month ago by
KolesnikovAkexandr.
February 14, 2018 at 23:02 #20108support
Thanks for the explanation. Please try using the team settings as shown in this tutorial: https://visualgdb.com/tutorials/ci/tfs/
Please configure your CI server to set the AGENT_WORKFOLDER environment variable to any non-empty value so VisualGDB will detect that it’s running from a build server and will apply team settings & rebuild the missing files fully automatically.
February 19, 2018 at 12:50 #20175KolesnikovAkexandr
ParticipantI have little progress and almost build a project. But now I have error message:
ExecutePrebuildActions:
VisualGDB version 5.3.18.1973
System.InvalidOperationException
System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
at d81.m(String a, Object[] b)
at oh1.f_4(ck1 a)
at p52..ctor(VisualGDBProjectSettings2 b, mc c, IDELevelProjectInfoForBuilding d, uz a)
at VisualGDB.MSBuild.BuildHelper..ctor(String vgdbSettingsFile, IDELevelProjectInfoForBuilding info)
at Sysprogs.build.tasks.shared.LaunchVisualGDB.Execute()
C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\external.targets(5,3): error : Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service applicationFebruary 20, 2018 at 05:14 #20178support
This looks like VisualGDB fails to initialize and the service configuration is preventing it from displaying the error message properly (likely due to missing per-user configuration files). Please try temporarily configuring the service as an interactive service so that you can see the VisualGDB error messages). Please also ensure you run VisualGDB from the same user account that you used to configure it (toolchain definitions and other settings are stored separately for each user).
