VisualGDB and Environmental Modules
Sysprogs forums Forums VisualGDB VisualGDB and Environmental Modules
  • This topic has 1 reply, 2 voices, and was last updated 12 years ago by ket.
  • #604
    kbzowski
    Our develop server use Environmental Modules (http://modules.sourceforge.net/) which requires loading necessary modules before compiling and running applications.
    It has been done by command ‘module load xxx’. Where I can put that command to execute before compile, and GDB run?
    #2529
    ket
    Usually the full custom project is used to execute sequences of commands for building and debugging. With the upcoming version of VisualGDB, there will also be a possibility of extending Linux projects with custom command sequences pre and post build/debug commands.
