Sysprogs forums › Forums › VisualGDB › VisualGDB 5.3-trial Installer Hangs
- This topic has 3 replies, 2 voices, and was last updated 8 years, 4 months ago by
Seidleroni.
October 12, 2017 at 12:33 #12644
Seidleroni
ParticipantI’ve tried several times now, but when I install VisualGDB v5.3-trial.msi, it hangs about 2/3rds of the way through and never completes. I gave it hours to see what would happen, but it is still stuck. Is there a log file I can look at to see what the problem could be? I tried using the ‘custom’ installer and only having it install the embedded edition for VS2017 with the same result. Any suggestions?
October 12, 2017 at 12:50 #12645Seidleroni
ParticipantI was able to get the log by calling the installer with the /i* parameter. The log contents are below. Any idea what the issue could be?
=== Logging started: 10/12/2017 7:47:30 ===
Action 7:47:30: INSTALL.
Action start 7:47:30: INSTALL.
Action 7:47:30: FindRelatedProducts. Searching for related applications
Action start 7:47:30: FindRelatedProducts.
FindRelatedProducts: Found application: {72B37D99-EAF9-4D62-9CD9-915B07371007}
Action ended 7:47:30: FindRelatedProducts. Return value 1.
Action 7:47:30: PrepareDlg.
Action start 7:47:30: PrepareDlg.
Info 2898.For WixUI_Font_Normal textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 13 pixels height.
Info 2898.For WixUI_Font_Bigger textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 19 pixels height.
Action 7:47:30: PrepareDlg. Dialog created
Action ended 7:47:30: PrepareDlg. Return value 1.
Action 7:47:30: VSFindInstances.
Action start 7:47:30: VSFindInstances.
Action ended 7:47:30: VSFindInstances. Return value 1.
Action 7:47:30: AppSearch. Searching for installed applications
Action start 7:47:30: AppSearch.
AppSearch: Property: INTEGRATED_VS90, Signature: VS90VGDBRegistrySearch
AppSearch: Property: INTEGRATED_VS2010, Signature: VS2010VGDBRegistrySearch
AppSearch: Property: INTEGRATED_VS2012, Signature: VS2012VGDBRegistrySearch
AppSearch: Property: INTEGRATED_VS2013, Signature: VS2013VGDBRegistrySearch
AppSearch: Property: INTEGRATED_VS2015, Signature: VS2015VGDBRegistrySearch
AppSearch: Property: INTEGRATED_VS2017, Signature: VS2017VGDBRegistrySearch
AppSearch: Property: VS2017_DIRECTORY_ALTERNATE, Signature: VS2017DevEnvSearch_Fix
AppSearch: Property: USAGE_REPORTS_ENABLED_ON_LAUNCH, Signature: rsSEND_USAGE_REPORTS
AppSearch: Property: VS90_ROOT_FOLDER, Signature: SearchForVS90RootPath
AppSearch: Property: VS90DEVENV, Signature: VS90DevEnvSearch
AppSearch: Property: VS2010_ROOT_FOLDER, Signature: SearchForVS2010RootPath
AppSearch: Property: VS2010DEVENV, Signature: VS2010DevEnvSearch
AppSearch: Property: VS2012_ROOT_FOLDER, Signature: SearchForVS2012RootPath
AppSearch: Property: VS2012DEVENV, Signature: VS2012DevEnvSearch
AppSearch: Property: VS2013_ROOT_FOLDER, Signature: SearchForVS2013RootPath
AppSearch: Property: VS2013DEVENV, Signature: VS2013DevEnvSearch
AppSearch: Property: VS2015_ROOT_FOLDER, Signature: SearchForVS2015RootPath
AppSearch: Property: VS2015DEVENV, Signature: VS2015DevEnvSearch
AppSearch: Property: VS2017DEVENV, Signature: VS2017DevEnvSearch
AppSearch: Property: VS2017_IDE_DIR, Signature: VS2017EnvironmentDirectorySearch
Action ended 7:47:30: AppSearch. Return value 1.
Action 7:47:30: SetVS2017_ROOT_FOLDER.
Action start 7:47:30: SetVS2017_ROOT_FOLDER.
Action ended 7:47:30: SetVS2017_ROOT_FOLDER. Return value 1.
Action 7:47:30: LaunchConditions. Evaluating launch conditions
Action start 7:47:30: LaunchConditions.
Action ended 7:47:30: LaunchConditions. Return value 1.
Action 7:47:30: SetcaTouchExtensionsFile.
Action start 7:47:30: SetcaTouchExtensionsFile.
Action ended 7:47:30: SetcaTouchExtensionsFile. Return value 1.
Action 7:47:30: SetINSTALL_VS2015.
Action start 7:47:30: SetINSTALL_VS2015.
Action ended 7:47:30: SetINSTALL_VS2015. Return value 1.
Action 7:47:30: SetINSTALL_VS2017.
Action start 7:47:30: SetINSTALL_VS2017.
Action ended 7:47:30: SetINSTALL_VS2017. Return value 1.
Action 7:47:30: ValidateProductID.
Action start 7:47:30: ValidateProductID.
Action ended 7:47:30: ValidateProductID. Return value 1.
Action 7:47:30: CostInitialize. Computing space requirements
Action start 7:47:30: CostInitialize.
Action ended 7:47:30: CostInitialize. Return value 1.
Action 7:47:30: FileCost. Computing space requirements
Action start 7:47:30: FileCost.
Action ended 7:47:30: FileCost. Return value 1.
Action 7:47:30: CostFinalize. Computing space requirements
Action start 7:47:30: CostFinalize.
Action ended 7:47:31: CostFinalize. Return value 1.
Action 7:47:31: MigrateFeatureStates. Migrating feature states from related applications
Action start 7:47:31: MigrateFeatureStates.
Action ended 7:47:31: MigrateFeatureStates. Return value 1.
Action 7:47:31: WelcomeDlg.
Action start 7:47:31: WelcomeDlg.
Action 7:47:31: WelcomeDlg. Dialog created
Info 2898.For WixUI_Font_Title textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 14 pixels height.
Action 7:47:31: LicenseAgreementDlg. Dialog created
Info 2898.For WixUI_Font_Normal_Bold textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 13 pixels height.
Action 7:47:33: SetupTypeDlgEx. Dialog created
Action 7:47:36: CustomizeDlg. Dialog created
Action 7:47:41: VisualStudioSelectDlg. Dialog created
Action 7:47:43: VerifyReadyDlg. Dialog created
Action ended 7:47:44: WelcomeDlg. Return value 1.
Action 7:47:44: ProgressDlg.
Action start 7:47:44: ProgressDlg.
Action 7:47:44: ProgressDlg. Dialog created
Action ended 7:47:44: ProgressDlg. Return value 1.
Action 7:47:44: ExecuteAction.
Action start 7:47:44: ExecuteAction.
Action 7:47:45: INSTALL.
Action start 7:47:45: INSTALL.
Action 7:47:45: FindRelatedProducts. Searching for related applications
Action start 7:47:45: FindRelatedProducts.
Action ended 7:47:45: FindRelatedProducts. Return value 0.
Action 7:47:45: VSFindInstances.
Action start 7:47:45: VSFindInstances.
Action ended 7:47:45: VSFindInstances. Return value 0.
Action 7:47:45: AppSearch. Searching for installed applications
Action start 7:47:45: AppSearch.
Action ended 7:47:45: AppSearch. Return value 0.
Action 7:47:45: SetVS2017_ROOT_FOLDER.
Action start 7:47:45: SetVS2017_ROOT_FOLDER.
Action ended 7:47:45: SetVS2017_ROOT_FOLDER. Return value 1.
Action 7:47:45: LaunchConditions. Evaluating launch conditions
Action start 7:47:45: LaunchConditions.
Action ended 7:47:45: LaunchConditions. Return value 1.
Action 7:47:45: SetcaTouchExtensionsFile.
Action start 7:47:45: SetcaTouchExtensionsFile.
Action ended 7:47:45: SetcaTouchExtensionsFile. Return value 1.
Action 7:47:45: SetINSTALL_VS2015.
Action start 7:47:45: SetINSTALL_VS2015.
Action ended 7:47:45: SetINSTALL_VS2015. Return value 1.
Action 7:47:45: SetINSTALL_VS2017.
Action start 7:47:45: SetINSTALL_VS2017.
Action ended 7:47:45: SetINSTALL_VS2017. Return value 1.
Action 7:47:45: ValidateProductID.
Action start 7:47:45: ValidateProductID.
Action ended 7:47:45: ValidateProductID. Return value 1.
Action 7:47:45: CostInitialize. Computing space requirements
Action start 7:47:45: CostInitialize.
Action ended 7:47:45: CostInitialize. Return value 1.
Action 7:47:45: FileCost. Computing space requirements
Action start 7:47:45: FileCost.
Action ended 7:47:45: FileCost. Return value 1.
Action 7:47:45: CostFinalize. Computing space requirements
Action start 7:47:45: CostFinalize.
Action ended 7:47:45: CostFinalize. Return value 1.
Action 7:47:45: MigrateFeatureStates. Migrating feature states from related applications
Action start 7:47:45: MigrateFeatureStates.
Action ended 7:47:45: MigrateFeatureStates. Return value 0.
Action 7:47:45: InstallValidate. Validating install
Action start 7:47:45: InstallValidate.
Action ended 7:47:45: InstallValidate. Return value 1.
Action 7:47:45: RemoveExistingProducts. Removing applications
Action start 7:47:45: RemoveExistingProducts.
RemoveExistingProducts: Application: {72B37D99-EAF9-4D62-9CD9-915B07371007}, Command line: UPGRADINGPRODUCTCODE={020C3694-E978-46E8-870F-83549561CE67} CLIENTUILEVEL=0 REMOVE=ALL
Action start 7:47:45: VSFindInstances.October 12, 2017 at 19:37 #12647support
It looks like something inside the logic responsible for finding VS instances hangs. It’s hard to say what would be causing this, so we could only give some generic advice:
- See if msiexec.exe launches any other tools or tries to access some inaccessible paths or registry keys (using Process Monitor).
- Try reinstalling/uninstalling Visual Studio.
- Try completely uninstalling the previous version of VisualGDB and installing the new one. If this doesn’t help, try running the v5.2 installer and check if it hangs the same way.
October 17, 2017 at 19:18 #12692Seidleroni
ParticipantUninstalling/Reinstalling VisualGDB did the trick. After doing so, I had to rebuild the MSBuild file but that was pretty painless.
