Sysprogs forums › Forums › VisualGDB › VisualGDB 5.0 Intellisens Clang suggestions
- This topic has 4 replies, 2 voices, and was last updated 10 years, 11 months ago by
April 17, 2015 at 19:53 #6353
peer23peer
ParticipantMy current configuration is Visual Studio 2015, with VisualGDB 5.0 prev 4 and on my linux computer the compiler is Clang 3.6.0.
Compiling and running the code works but I got an issue with the intellisense, it doesn’t give any suggestions for members and methods for the class that i’m working in, it only shows the pull down menu when I start typing with this->
It also give me a lot of errors for files that are in the remotesourcecache, namely the /usr/bin/../lib/clang/3.6.0/include folder:
Severity Description Project File Line Column
Error [Clang IntelliSense] Error: too many errors emitted, stopping now 1 1
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature emmintrin.h 98 10
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature emmintrin.h 158 10
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature emmintrin.h 164 10
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 46 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 70 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 76 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 82 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 88 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 94 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 100 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 106 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 112 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 118 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 124 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 130 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 136 12
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature mmintrin.h 142 12
Message [Clang IntelliSense] previous declaration is here Miscellaneous Files stdlib.h 503 12etc….
Does anybody has any sugestions
April 18, 2015 at 00:23 #6354support
Can you attach a screenshot of the emmintrin.h file showing the error location and the color of tokens around it?
Does your project specify -std=xxx explicitly in compiler flags? Can you open View->Clang IntelliSense Status, switch to Project Status and share the value of CFLAGS and CXXFLAGS displayed there?
Please also confirm whether the problem happens while trying to edit a .c or .cpp file.
April 18, 2015 at 09:20 #6366peer23peer
ParticipantHi Bazis,
The errors are always present, it doesn’t matter if I’m currently working in *.h or *.cpp file
I’m compiling with the -std=c++11 flag and use cmake, building is done using make -j4
below is the CmakeList.txt of my startup project a BOOST unit test for various custom libraries all compiled with the same flag
#Generated by VisualGDB project wizard.
#Note: VisualGDB will automatically update this file when you add new sources to the project.cmake_minimum_required(VERSION 2.7)
project(VSA_UT)
ADD_DEFINITIONS(-DBOOST_TEST_DYN_LINK -DDEBUG)
SET(CMAKE_INSTALL_RPATH_USE_LINK_PATH TRUE)set(LIBRARIES_FROM_REFERENCES ${CMAKE_SOURCE_DIR}/../../../../src/VisionSoilAnalyzer/Vision/Debug/libVision.so ${CMAKE_SOURCE_DIR}/../../../../src/VisionSoilAnalyzer/Soil/Debug/libSoil.so ${CMAKE_SOURCE_DIR}/../../../../src/VisionSoilAnalyzer/SoilPlot/Debug/libSoilPlot.so ${CMAKE_SOURCE_DIR}/../../../../src/VisionSoilAnalyzer/SoilMath/Debug/libSoilMath.so)
add_executable(VSA_UT VSA_UT.cpp)
target_link_libraries(VSA_UT -L/usr/local/lib -L/usr/lib/x86_64-linux-gnu/ -lopencv_calib3d -lopencv_core -lopencv_features2d -lopencv_imgproc -lopencv_flann -lopencv_highgui -lopencv_imgcodecs -lopencv_ml -lopencv_objdetect -lopencv_photo -lopencv_shape -lopencv_stitching -lopencv_superres -lopencv_ts -lopencv_video -lopencv_videoio -lopencv_videostab “${LIBRARIES_FROM_REFERENCES}” -lboost_serialization -lboost_unit_test_framework)
include_directories (/usr/local/include /usr/local/include/opencv /usr/include/boost)
set(CMAKE_C_FLAGS “${CMAKE_C_FLAGS} -std=c++11”)
set(CMAKE_CXX_FLAGS “${CMAKE_CXX_FLAGS} -std=c++11”)—————————————————————————————————–
Screenshot doesn’t give clear information, they are all red lines at the first “(” after the return keyword. zie table below for specific line and column
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature Miscellaneous Files emmintrin.h 98 10
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature Miscellaneous Files emmintrin.h 158 10
Error [Clang IntelliSense] Error: compound literals are a C99-specific feature Miscellaneous Files emmintrin.h 164 10—————————————————————————————————————————
static __inline__ __m128d __attribute__((__always_inline__, __nodebug__))
_mm_sqrt_sd(__m128d __a, __m128d __b)
__m128d __c = __builtin_ia32_sqrtsd(__b);
return (__m128d) { __c[0], __a[1] };
_mm_cmpeq_pd(__m128d __a, __m128d __b)
return (__m128d)__builtin_ia32_cmpeqpd(__a, __b);
_mm_cmplt_pd(__m128d __a, __m128d __b)
return (__m128d)__builtin_ia32_cmpltpd(__a, __b);
}This is also the cause for most of the errors that I checked in the files: mmintrin.h , xmmintrin.h
April 18, 2015 at 09:25 #6367peer23peer
ParticipantSorry forgot to mention the flags of the CLANG intellisense:
Main project:
CFlag
–target=x86_64 -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10006\4.8 -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10007\4.8 -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10006\4.8\backward -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10003\include -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10000\include\x86_64-linux-gnu -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10000\include -IC:\Users\jelle\AppData\Local\VisualGDB\RemoteSourceCache\192.168.178.10004\include -include D:\OneDrive\Opleiding\HTS_HAN\Minor2\CPP\VisionSoilAnalyzer\Tests\UnitTest\VSA_UT\VSA_UT\gcc_Debug.h -include C:\Program Files (x86)\Sysprogs\VisualGDB\gcc_compat.h -std=c++11 -D__SYSPROGS_CODESENSE__
CXX Flag
April 19, 2015 at 17:33 #6374support
Can you try replacing -std=c++11 with -std=gnu++11?
