VisualDDK symbols & breakpoints
Sysprogs forums Forums VisualDDK/VirtualKD discussion VisualDDK symbols & breakpoints
  • #363
    sn0w
    hi guys! who can explain, why the symbols couldnot be loaded?!? in a previous(first) session all of them were downloaded automatically via VS & VKD and stored in symbol dir, all modules was with correct Symbol File and Symbol status fields, but now something strange happens, and the .pdb still in the specified folder
    i misunderstand, what happened with a symbols?! i even cant set a breakpoint via command prompt =(
    (btw – this is normal that i have no reply on bl when the several bps still in breakpoint list?)
    #1983
    sn0w
    symbol path is set. and there is a correct symbols, but why it cant see them
    #1984
    try the .reload command
    also see the VisualDDK settings window to customize symbol-related behavior
    #1982
    sn0w
    VisualDDK configured to query MS sym svrs for modules seen first time, and to load for all mods.
    but solved, i’d unexpected this way: .reload /f /d /v executed too fast, but finally did nothing
    VisualDDK symbol path is set to: c:Symbols
    Visual studio symbol cache is set to: C:Symbols_studio (VS concats this path with trailing “MicrosoftPublicSymbols”)
    symbol load began to work properly when ive copied content from c:symbols to c:symbols_studioMicrosoftPublicSymbols
