I have installed VisualStudio 2008 and DDK 3790.1830 and WDK 7600.16385.0. Some projects are Windows 2000 device driver, so I select the 3790.1830 DDK during converting of an existing project with VisualDDK driver wizzard to a WDK build project. But it do not build cause in the build command lines WDKPATH is used instead of DDKPATH (setenv with W2K parameter does not work since 7600.16385.0 does not have W2K option anymore). If I change that manually, the project builds. For Intellisense section the right DDKPATH is used. A bug?
Mike.
