Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › visualddk issues
- This topic has 1 reply, 1 voice, and was last updated 13 years, 2 months ago by
Anonymous.
January 21, 2013 at 02:44 #369
First of all this project sounds very interesting, thank you for your hard work!!
first I tried my luck with virtualbox 4.2 (I tried to compile the modules, as far as it goes for the c++ modules it seems like it was okay, I had to convert several configurations to visual studio 10). Although finally I gave up on it because vmmon did not work correctly neither with the latest virtualbox header.
So then I tried to switch back to virtualbox 4.1, at a first glance it seemed to work, however it quickly end up nowhere.
Now if I start vmmon I get the message
VirtualKD cannot patch Virtualbox on the fly.
Please register the virtualkd device for virtualbox by running regsvr32 vboxkd64.dll if this does not help, close all instances of virtualbox and terminate …Can you please update the sources with the latest version? Because there seems to be a mismatch between the binaries which you offer and the sources which are downloadable
UPDATE WHILE WRITING THAT, I did above thing a 3rd time 2 times it failed.
I left the virtual machine monitor running in the background and only restarted virtualbox (restarting the vmmon would probably lead to the same problem which I had just before).OK so let’s go on here, in Visual Studio 10 I’m starting th eVisualDDK Driver Project Launcher and set up windows 7 through the 3rd “debugging connection setup” option and click Save, everything okay until here
secondly I open that one again and click launch and I get an error (sorry it vanished too quick I’ll try to catch it next time)
I open the Driver Project launcher again and it seems to go on now – wait stop nothing happens.
Ok I close the virtual machine monitor and it really goes on, on the VisualDDK Console I can see many Unable to deliver callback, 31 messages does anyone know what that means?Ok going on from here I start up windows and start the launch monitor the launch monitor prints “discovery request from 192.168.2.226”
while doing that the “driver launch in progress” window only prints
Contacting VisualDDK Launch monitor on via UDP…
Detecting remote machine IP address…I’m stuck here… I’ll keep updating this when it goes on. If someone has some more experience with it please help 🙂
January 21, 2013 at 04:53 #1994Anonymous
ParticipantFinally I got it work too.
I started up vmmon and I’m using the named pipe to connect to the win7 vm.
Driver loading and unloading works! (no lockup of visual studio like another user reported in the forum).
When it tries to discover the remote host I picked the IP address of the virtual machine and entered it manually (it did not seem like an input field because it flashes quickly and deletes all the input, so typing in the IP address is impossible but someone can copy and paste the ip address and press return quickly
bazis it would be really nice if you could update this genius application and/or the sourcecode for it
