Visual gdb return 0 on a failed unit test
Sysprogs forums › Forums › VisualGDB › Visual gdb return 0 on a failed unit test
  • #26731
    Markg
    We are integrating our unit tests into our jenkins environment, but on a failed unit test the visualgdb executer returns 0 (succes) Is there a way that visualgdb returns a failure so this can be detected by jenkins?
    Regards,
    Mark
    #26738
    The return code of 0 means that the there was no critical error preventing VisualGDB from launching the tests. You can find out the specific tests that succeeded/failed by analyzing the report file generated by either /output or /vsoutput option (see this thread).
    If this doesn’t help, please let us know what exactly you are trying to accomplish and we will try to suggest the best setup for it.
