Visual GDB failing to run: Modal Dialog
Sysprogs forums Forums VisualGDB Visual GDB failing to run: Modal Dialog
  • #11092
    CurtisHx
    We’re having a problem on our TFS 2017 build environment where VisualGDB won’t run when it is invoked as part of an official build through TFS.  I can run the build manually on the build machine by calling “msbuild myproject.proj” from a developer console.  But it will not run through TFS.
    Here’s the error message.
    12>ExecutePrebuildActions:
    System.InvalidOperationException
    System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
    at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
    at ft1.n(String a, Object[] b)
    at n61.f_2(m5 a)
    at b2..ctor(VisualGDBProjectSettings2 b, pa1 c, d1 a)
    at VisualGDB.MSBuild.BuildHelper..ctor(String vgdbSettingsFile)
    at Sysprogs.build.tasks.shared.LaunchVisualGDB.Execute()
    12>C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\external.targets(5,3): error : Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
    #11115
    Please let us know the exact VisualGDB build number (can be located via file properties for VisualGDB.exe) so that we could check why this window is shown.
