Sysprogs forums › Forums › VisualGDB › Visual GDB Esp32 Flash Button Doesn't Work
- This topic has 3 replies, 2 voices, and was last updated 4 years, 8 months ago by
January 13, 2022 at 09:05 #32021
elaborate
ParticipantVisual GDB Esp32 Flash Button Doesn’t Work
IDF :4.3.2
Toolchain: esp32-gcc8.4.0-r7
Visual Studio 2022 Community Latest
VisualGDB 5.6R2 (build 4521)
Project clean and Rebuild but doesn’t change the results. please look at the gif file
This topic was modified 4 years, 8 months ago by
elaborate.
January 13, 2022 at 09:12 #32023support
You can read more about the best way to report VisualGDB issues in our problem reporting guidelines.
January 13, 2022 at 11:27 #32027elaborate
Participantthis old project file doesn’t work. i created new project and copy structure works well
<h1>old structure:</h1>
<?xml version=”1.0″?>
<VisualGDBProjectSettings2 xmlns:xsd=”http://www.w3.org/2001/XMLSchema” xmlns:xsi=”http://www.w3.org/2001/XMLSchema-instance”>
<Project xsi:type=”com.visualgdb.project.external.esp-idf”>
<CustomSourceDirectories>
<Directories />
<PathStyle>Unknown</PathStyle>
</CustomSourceDirectories>
<AutoProgramSPIFFSPartition>true</AutoProgramSPIFFSPartition>
<ProjectModeSettings>
<ProjectGUID>da9e8a85-e94c-4371-8268-7f621fcca65a</ProjectGUID>
<GroupSourcesByTypes>true</GroupSourcesByTypes>
<GroupSourcesByPaths>true</GroupSourcesByPaths>
<HeaderScanMode>SourceDirs</HeaderScanMode>
</ProjectModeSettings>
<TestSettings>
<InitializationTimeout>30</InitializationTimeout>
<DefaultTestTimeout>60</DefaultTestTimeout>
<ApptraceInitializationTimeout>5</ApptraceInitializationTimeout>
<FinalizationTimeout>5</FinalizationTimeout>
</TestSettings>
</Project>
<Build xsi:type=”com.visualgdb.build.cmake”>
<BuildLogMode xsi:nil=”true” />
<ToolchainID>
<ID>com.visualgdb.xtensa-esp32-elf</ID>
<Version>
<GCC>8.4.0</GCC>
<GDB>8.1.0</GDB>
<Revision>7</Revision>
</Version>
</ToolchainID>
<RelativeSourceDirectory />
<ConfigurationType>DEBUG</ConfigurationType>
<BinaryDirectory>build/$(PlatformName)/$(ConfigurationName)</BinaryDirectory>
<MakeCommandTemplate>
<SkipWhenRunningCommandList>false</SkipWhenRunningCommandList>
<RemoteHost>
<HostName>BuildMachine</HostName>
<Transport>BuiltinShortcut</Transport>
</RemoteHost>
<Command>$(ToolchainNinja)</Command>
<WorkingDirectory>$(BuildDir)</WorkingDirectory>
<BackgroundMode xsi:nil=”true” />
</MakeCommandTemplate>
<CMakeCommand>
<RemoteHost>
</RemoteHost>
<Command>$(SYSPROGS_CMAKE_PATH)</Command>
</CMakeCommand>
<UpdateSourcesInCMakeFile>true</UpdateSourcesInCMakeFile>
<ExportCompileCommands>false</ExportCompileCommands>
<DisableToolchainFile>false</DisableToolchainFile>
<CMakeMakefileType>Ninja</CMakeMakefileType>
<DeployAsRoot>false</DeployAsRoot>
<CMakeCleanMode>RemoveBuildDirectory</CMakeCleanMode>
<UseCCache>false</UseCCache>
<ProjectItemSettings>
<GroupTargetsByPaths>true</GroupTargetsByPaths>
<FollowCMakeSourceGroups>false</FollowCMakeSourceGroups>
<AutoRefreshProject>true</AutoRefreshProject>
<AlwaysConsiderOutdated>false</AlwaysConsiderOutdated>
<SortTargetsByName>true</SortTargetsByName>
<RedundantTargetMode>HideOuterProjectTargets</RedundantTargetMode>
<SortSourcesByName>true</SortSourcesByName>
<BuildAllTargetsInSubdir>false</BuildAllTargetsInSubdir>
<FoldSingleItemPathLevels>true</FoldSingleItemPathLevels>
</ProjectItemSettings>
<TargetSpecificSettings />
<SetLDLibraryPathFromDependentArtifacts>true</SetLDLibraryPathFromDependentArtifacts>
<ProjectGUID>950e5430-6b8e-42ff-8232-6dfaac90bf67</ProjectGUID>
<VirtualFolders />
<ConfigurationNameCase>Upper</ConfigurationNameCase>
<DefaultHeaderDiscoveryMode>HeaderDirectoryAndSubdirectories</DefaultHeaderDiscoveryMode>
<EnableFastUpToDateCheck>true</EnableFastUpToDateCheck>
<ESPIDFExtension>
<IDFCheckout>
<Version>v4.3.1</Version>
<Subdirectory>esp-idf/v4.3.1</Subdirectory>
<Type>ESPIDF</Type>
</IDFCheckout>
<COMPort>COM3</COMPort>
<BaudRate>921600</BaudRate>
<SuppressTestPrerequisiteChecks>false</SuppressTestPrerequisiteChecks>
<DeviceID>ESP32</DeviceID>
</ESPIDFExtension>
</Build>
<CustomBuild>
<PreSyncActions />
<PreBuildActions />
<PostBuildActions />
<PreCleanActions />
<PostCleanActions />
</CustomBuild>
<CustomDebug>
<PreDebugActions />
<PostDebugActions />
<DebugStopActions />
<BreakMode>Default</BreakMode>
<CustomBreakCommand>
<RemoteHost>
</RemoteHost>
</CustomBreakCommand>
</CustomDebug>
<DeviceTerminalSettings>
<Connection xsi:type=”com.sysprogs.terminal.connection.serial”>
<ComPortName>COM3</ComPortName>
<AdvancedSettings>
<BaudRate>115200</BaudRate>
<DataBits>8</DataBits>
<Parity>None</Parity>
<StopBits>One</StopBits>
<FlowControl>None</FlowControl>
</AdvancedSettings>
</Connection>
<LastConnectionTime>0</LastConnectionTime>
<EchoTypedCharacters>true</EchoTypedCharacters>
<ClearContentsWhenReconnecting>true</ClearContentsWhenReconnecting>
<ReconnectAutomatically>true</ReconnectAutomatically>
<DisplayMode>ASCII</DisplayMode>
<Colors>
<Background>
<Alpha>255</Alpha>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Background>
<Disconnected>
<Alpha>255</Alpha>
<Red>169</Red>
<Green>169</Green>
<Blue>169</Blue>
</Disconnected>
<Text>
<Alpha>255</Alpha>
<Red>211</Red>
<Green>211</Green>
<Blue>211</Blue>
</Text>
<Echo>
<Alpha>255</Alpha>
<Red>144</Red>
<Green>238</Green>
<Blue>144</Blue>
</Echo>
<Inactive>
<Alpha>255</Alpha>
<Red>169</Red>
<Green>169</Green>
<Blue>169</Blue>
</Inactive>
</Colors>
<HexSettings>
<MaximumBytesPerLine>16</MaximumBytesPerLine>
<ShowTextView>true</ShowTextView>
<BreaksAroundEcho>true</BreaksAroundEcho>
<AutoSend>true</AutoSend>
<SendAsHex>true</SendAsHex>
<TimeoutForAutoBreak>0</TimeoutForAutoBreak>
</HexSettings>
<LineEnding>LF</LineEnding>
<TreatLFAsCRLF>false</TreatLFAsCRLF>
<KeepOpenAfterExit>true</KeepOpenAfterExit>
<ShowAfterProgramming>true</ShowAfterProgramming>
</DeviceTerminalSettings>
<CustomShortcuts>
<Shortcuts />
<ShowMessageAfterExecuting>true</ShowMessageAfterExecuting>
</CustomShortcuts>
<UserDefinedVariables />
<ImportedPropertySheets />
<CodeSense>
<Enabled>True</Enabled>
<ExtraSettings>
<HideErrorsInSystemHeaders>true</HideErrorsInSystemHeaders>
<SupportLightweightReferenceAnalysis>true</SupportLightweightReferenceAnalysis>
<DiscoverySettings>
<Mode>Enabled</Mode>
<SearchInProjectDir>true</SearchInProjectDir>
<SearchInSourceDirs>true</SearchInSourceDirs>
<SearchInIncludeSubdirs>true</SearchInIncludeSubdirs>
</DiscoverySettings>
<CheckForClangFormatFiles xsi:nil=”true” />
<FormattingEngine xsi:nil=”true” />
</ExtraSettings>
<CodeAnalyzerSettings>
<Enabled>true</Enabled>
<SelectedAnalyzers>
<string>alpha.clone.CloneChecker</string>
<string>alpha.core.BoolAssignment</string>
<string>alpha.core.CallAndMessageUnInitRefArg</string>
<string>alpha.core.CastSize</string>
<string>alpha.core.CastToStruct</string>
<string>alpha.core.Conversion</string>
<string>alpha.core.DynamicTypeChecker</string>
<string>alpha.core.FixedAddr</string>
<string>alpha.core.IdenticalExpr</string>
<string>alpha.core.PointerArithm</string>
<string>alpha.core.PointerSub</string>
<string>alpha.core.SizeofPtr</string>
<string>alpha.core.StackAddressAsyncEscape</string>
<string>alpha.core.TestAfterDivZero</string>
<string>alpha.cplusplus.DeleteWithNonVirtualDtor</string>
<string>alpha.cplusplus.IteratorRange</string>
<string>alpha.cplusplus.MisusedMovedObject</string>
<string>alpha.deadcode.UnreachableCode</string>
<string>alpha.security.ArrayBound</string>
<string>alpha.security.ArrayBoundV2</string>
<string>alpha.security.MallocOverflow</string>
<string>alpha.security.ReturnPtrRange</string>
<string>alpha.security.taint.TaintPropagation</string>
<string>alpha.unix.BlockInCriticalSection</string>
<string>alpha.unix.Chroot</string>
<string>alpha.unix.cstring.BufferOverlap</string>
<string>alpha.unix.cstring.NotNullTerminated</string>
<string>alpha.unix.cstring.OutOfBounds</string>
<string>alpha.unix.PthreadLock</string>
<string>alpha.unix.SimpleStream</string>
<string>alpha.unix.Stream</string>
<string>apiModeling.google.GTest</string>
<string>core.builtin.BuiltinFunctions</string>
<string>core.builtin.NoReturnFunctions</string>
<string>core.CallAndMessage</string>
<string>core.DivideZero</string>
<string>core.DynamicTypePropagation</string>
<string>core.NonnilStringConstants</string>
<string>core.NonNullParamChecker</string>
<string>core.NullDereference</string>
<string>core.StackAddressEscape</string>
<string>core.UndefinedBinaryOperatorResult</string>
<string>core.uninitialized.ArraySubscript</string>
<string>core.uninitialized.Assign</string>
<string>core.uninitialized.Branch</string>
<string>core.uninitialized.CapturedBlockVariable</string>
<string>core.uninitialized.UndefReturn</string>
<string>core.VLASize</string>
<string>cplusplus.NewDelete</string>
<string>cplusplus.NewDeleteLeaks</string>
<string>cplusplus.SelfAssignment</string>
<string>deadcode.DeadStores</string>
<string>llvm.Conventions</string>
<string>nullability.NullableDereferenced</string>
<string>nullability.NullablePassedToNonnull</string>
<string>nullability.NullableReturnedFromNonnull</string>
<string>nullability.NullPassedToNonnull</string>
<string>nullability.NullReturnedFromNonnull</string>
<string>optin.cplusplus.VirtualCall</string>
<string>optin.mpi.MPI-Checker</string>
<string>optin.osx.cocoa.localizability.EmptyLocalizationContextChecker</string>
<string>optin.osx.cocoa.localizability.NonLocalizedStringChecker</string>
<string>optin.performance.Padding</string>
<string>optin.portability.UnixAPI</string>
<string>security.FloatLoopCounter</string>
<string>security.insecureAPI.getpw</string>
<string>security.insecureAPI.gets</string>
<string>security.insecureAPI.mkstemp</string>
<string>security.insecureAPI.mktemp</string>
<string>security.insecureAPI.rand</string>
<string>security.insecureAPI.strcpy</string>
<string>security.insecureAPI.UncheckedReturn</string>
<string>security.insecureAPI.vfork</string>
<string>unix.API</string>
<string>unix.cstring.BadSizeArg</string>
<string>unix.cstring.NullArg</string>
<string>unix.Malloc</string>
<string>unix.MallocSizeof</string>
<string>unix.MismatchedDeallocator</string>
<string>unix.StdCLibraryFunctions</string>
<string>unix.Vfork</string>
<string>valist.CopyToSelf</string>
<string>valist.Uninitialized</string>
<string>valist.Unterminated</string>
</SelectedAnalyzers>
<ExtraArguments>
<string>-analyzer-store=region</string>
<string>-analyzer-opt-analyze-nested-blocks</string>
<string>-analyzer-eagerly-assume</string>
</ExtraArguments>
</CodeAnalyzerSettings>
</CodeSense>
<Configurations>
<VisualGDBConfiguration>
<Name>Debug</Name>
<BuildSettingsExtension xsi:type=”com.visualgdb.build.external.esp-idf.cmake.extension” />
</VisualGDBConfiguration>
<Name>Release</Name>
</Configurations>
<ProgramArgumentsSuggestions />
<Debug xsi:type=”com.visualgdb.debug.embedded”>
<AdditionalStartupCommands>
<GDBPreStartupCommands />
<GDBStartupCommands />
<GDBFinalizationCommands />
</AdditionalStartupCommands>
<AdditionalGDBSettings>
<Features>
<DisableAutoDetection>false</DisableAutoDetection>
<UseFrameParameter>false</UseFrameParameter>
<SimpleValuesFlagSupported>false</SimpleValuesFlagSupported>
<ListLocalsSupported>false</ListLocalsSupported>
<ByteLevelMemoryCommandsAvailable>false</ByteLevelMemoryCommandsAvailable>
<ThreadInfoSupported>false</ThreadInfoSupported>
<PendingBreakpointsSupported>false</PendingBreakpointsSupported>
<SupportTargetCommand>false</SupportTargetCommand>
<ReliableBreakpointNotifications>false</ReliableBreakpointNotifications>
</Features>
<EnableSmartStepping>false</EnableSmartStepping>
<FilterSpuriousStoppedNotifications>false</FilterSpuriousStoppedNotifications>
<ForceSingleThreadedMode>false</ForceSingleThreadedMode>
<UseAppleExtensions>false</UseAppleExtensions>
<CanAcceptCommandsWhileRunning>false</CanAcceptCommandsWhileRunning>
<MakeLogFile>false</MakeLogFile>
<IgnoreModuleEventsWhileStepping>true</IgnoreModuleEventsWhileStepping>
<UseRelativePathsOnly>false</UseRelativePathsOnly>
<ExitAction>None</ExitAction>
<DisableDisassembly>false</DisableDisassembly>
<ExamineMemoryWithXCommand>false</ExamineMemoryWithXCommand>
<StepIntoNewInstanceEntry>app_main</StepIntoNewInstanceEntry>
<ExamineRegistersInRawFormat>true</ExamineRegistersInRawFormat>
<DisableSignals>false</DisableSignals>
<EnableAsyncExecutionMode>false</EnableAsyncExecutionMode>
<AsyncModeSupportsBreakpoints>true</AsyncModeSupportsBreakpoints>
<TemporaryBreakConsolidationTimeout>0</TemporaryBreakConsolidationTimeout>
<EnableNonStopMode>false</EnableNonStopMode>
<MaxBreakpointLimit>0</MaxBreakpointLimit>
<EnableVerboseMode>true</EnableVerboseMode>
</AdditionalGDBSettings>
<DebugMethod>
<ID>gdbstub</ID>
<Configuration xsi:type=”com.visualgdb.edp.espxx.settings.gdbstub.esp32″>
<StubBaudRate>74880</StubBaudRate>
<BootloaderBaudRate>115200</BootloaderBaudRate>
<BootloaderResetDelay>50</BootloaderResetDelay>
<BootloaderActivationSequence>!DTR;RTS;SLEEP;DTR;!RTS;SLEEP;!DTR;SLEEP</BootloaderActivationSequence>
<ProgramMode>Enabled</ProgramMode>
<SuppressResetConfirmation>false</SuppressResetConfirmation>
<PatchBootloader>true</PatchBootloader>
<FLASHSettings>
<Size>size2MB</Size>
<Frequency>freq40M</Frequency>
<Mode>DIO</Mode>
</FLASHSettings>
</Configuration>
</DebugMethod>
<AutoDetectRTOS>true</AutoDetectRTOS>
<SemihostingSupport>Auto</SemihostingSupport>
<SemihostingPollingDelay>0</SemihostingPollingDelay>
<StepIntoEntryPoint>false</StepIntoEntryPoint>
<ReloadFirmwareOnReset>false</ReloadFirmwareOnReset>
<ValidateEndOfStackAddress>true</ValidateEndOfStackAddress>
<StopAtEntryPoint>false</StopAtEntryPoint>
<EnableVirtualHalts>false</EnableVirtualHalts>
<DynamicAnalysisSettings />
<EndOfStackSymbol>_estack</EndOfStackSymbol>
<TimestampProviderTicksPerSecond>0</TimestampProviderTicksPerSecond>
<KeepConsoleAfterExit>false</KeepConsoleAfterExit>
<UnusedStackFillPattern xsi:nil=”true” />
<CheckInterfaceDrivers>true</CheckInterfaceDrivers>
</Debug>
</VisualGDBProjectSettings2><h1>NEW</h1>
<Directories />
<ProjectGUID>5e7887b0-f156-41c8-8fbc-ceecac581a4b</ProjectGUID>
</Project>
<ToolchainID>
<Version>
<GCC>8.4.0</GCC>
<GDB>8.1.0</GDB>
</Version>
</ToolchainID>
<CMakeCommand>
</CMakeCommand>
<ProjectGUID>c0f4441c-b81b-4296-8dc1-9eb50252b144</ProjectGUID>
<VirtualFolders />
<ESPIDFExtension>
<IDFCheckout>
<Version>v4.3.2</Version>
<Subdirectory>esp-idf/v4.3.2</Subdirectory>
<Type>ESPIDF</Type>
</IDFCheckout>
</ESPIDFExtension>
</Build>
<CustomBuild>
<PreSyncActions />
<PreBuildActions />
<PreCleanActions />
</CustomBuild>
<CustomDebug>
<PreDebugActions />
</CustomDebug>
<CustomShortcuts>
<Shortcuts />
</CustomShortcuts>
<CodeSense>
<Enabled>Unknown</Enabled>
<ExtraSettings>
<CheckForClangFormatFiles>true</CheckForClangFormatFiles>
</ExtraSettings>
<Enabled>false</Enabled>
</CodeSense>
<Configurations>
<Name>Debug</Name>
</Configurations>
<AdditionalStartupCommands />
<Features>
</Features>
<EnablePrettyPrinters>false</EnablePrettyPrinters>
<DebugMethod>
<ID>gdbstub</ID>
<FLASHSettings>
<Mode>DIO</Mode>
</FLASHSettings>
</Configuration>
</DebugMethod>
</Debug>
</VisualGDBProjectSettings2>-
This reply was modified 4 years, 8 months ago by
elaborate.
January 13, 2022 at 11:30 #32029support
KeymasterGood to know it works. Please try comparing the old project against the new project, and adjusting it, eliminating the differences one-by-one. Once you can pinpoint a specific difference the is causing the problem, feel free to let us know and we can point the VisualGDB setting that is affecting it.
