VirtualKD + VBox > 4.3
Sysprogs forums Forums VisualDDK/VirtualKD discussion VirtualKD + VBox > 4.3
  • #6795
    edik
    My main question is about any way to connect VirtualKD 2.8 to VBox > 4.3.
    (I’m looking for a noob friendly one 😉 )
    I start installing the VirtualKD from here using VKD 2.8. exactly in step 2 it said
    Unable to cast COM object of type ‘VirtualBox.VirtualBoxClass’ …
    So I start Googleing and i found a great article here. I compiled the C# code and ran it in the VirtualKD-2.8 directory. the first problem is gone but the virtual box said:
    Unable to load R3 “C:\VirtualKD-2.8\VBoxKD64.dll”: Not signed … (VERR_LDRVI_NOT_SIGNED)
    Again I start Googleing… as I know the problem is for VBox > 3.1, it force signed dll loading in windows. so I signed the DLL by a self generated sign ( and of curse I added it to my trust list ). now the virtualbox braks with
    Unable to load R3 module “C:\VirtualKD-2.8\VBoxKD64.dll” None of 1 path(s) hav a trust anchor.: … (VERR_CR_X509_CPV_NO_TRUSTED_PATHS).
    so I used a globally trusted sign to do the job but I got a FATAL error from VBox, also I found the Avast version of VirtualKD (??!!) it is FATAL too.
    Finally I googled about the problem very much and the nearest result was VBOX_WITH_VIRTUALKD config flag and some change logs (4.3.16) about stub/loader.
    what is stub/loadr(?) is it enable in precompiled VBox binaries or I should recompile the source.
    • This topic was modified 10 years, 7 months ago by edik.
    #7020
    Please try version 3.0. It supports VirtualBox 5.0+.
