I’m using VisualGDB 5.6 Beta 3, build 4182. I found this small bug in the IDF projects: when you choose ESP32-C3 in Explore Solutions->VisualGDB project properties, click ok, when you try to enter again in VisualGDB project properties the chip chosen is ESP32 and not ESP32-C3, as if it is not retained in memory.
it is correct now. I’ve found another bug, but I’m not sure about it: I would like to use the USB Jtag/serial as console output, but if I try to set it in VisualGDB properties->ESP-IDF Project->Channel o console output->USB CDC and press OK, when I enter in the same menu again the option set is “Default: UART0”. All other options work: Default, Custom UART, None.
This could be something specific to ESP-IDF itself. E.g. the USB is not enabled for this project, hence the setting gets reverted back. Please try changing the same setting via ESP-IDF menuconfig (you can launch it via the context menu in Solution Explorer).
If menuconfig works as expected, please follow the steps below to narrow down the problem
Make a backup of the <project directory>\sdkconfig file before changing the setting.
Change the setting via VisualGDB Project Properties
Restore the backed up file
Change the same setting with menuconfig
Send us the 3 versions of the sdkconfig file (before, after editing with VisualGDB, after editing with menuconfig) along with the test project name, the ESP-IDF version and the device type, and we will try to reproduce the issue on our side.
