Using a ISP Interface with VisualGDB
Sysprogs forums › Forums › VisualGDB › Using a ISP Interface with VisualGDB
  • #12863
    Chrissel
    Hey,
    i have to make changes in an old avr project and the microprocessor doesn’t have JTAG, so i have to use ISP.
    Is there a good and simple way to use visualgdb for flashing ?
    As an interface, i have a old Olimex AVR-ISP500 and a newer AVRISP MKII.
    Chris
    #12871
    Olimex recommends using the open-source avrdude program with AVR-ISP500. VisualGDB currently doesn’t support it out-of-the-box, so you would need to install and configure it manually. If you can confirm that the command-line programming with avrdude works, we can help you configure your VisualGDB project to run it automatically.
    It could be also worth a try checking if the AVaRICE tool shipped with our AVR toolchain can recognize AVRISP MKII. If yes, you would not need to install any extra tools.
    #13247
    Michal
    I have the same problem. I’m using xmega microcontroller which isn’t supported in AVaRICE.
    It is possible to debug using avrdude? If yes, could you help me configure my VisualGDB project?
    Michal
    #13253
    Sorry, avrdude unfortunately doesn’t support debugging. Our best advice would be to try patching AVaRICE to add support for your device (it conveniently stores device descriptions in a single table in the source code), however we cannot guarantee that this would work.
