Sysprogs forums › Forums › VisualGDB › USB Driver Tool Does not work
- This topic has 9 replies, 4 voices, and was last updated 5 years, 2 months ago by
January 2, 2021 at 16:59 #29734
Jiahao Jian
ParticipantHi
I got a problem to use the USB Driver tool for the ESP32 devkit. The tool used to work.
Windows 10 Version 2oH2 OS build 19042.685
Could you please help ?
You must be logged in to view attached files.January 3, 2021 at 05:37 #29737microhaugen
Participanti get this message now in 2021.
Only solution is Zadig.exe
You must be logged in to view attached files.January 3, 2021 at 08:36 #29739support
We have confirmed the problem. It happens because the VeriSign timestamping service used by VisualGDB to sign the generated drivers with a temporary certificate stopped working. We have updated VisualGDB to use a different timestamping service. Please try this build: VisualGDB-5.5.104.3936.msi
January 3, 2021 at 13:17 #29743microhaugen
ParticipantYes, that solved it.
Thank you.
January 3, 2021 at 14:43 #29744Jiahao Jian
ParticipantTHANKS
January 5, 2021 at 06:19 #29756OSTerhase
ParticipantWe have the same errors but unfortunately the VisualGDB-5.5.104.3936.msi does not fix the problem.
We have Visual Studio 2019 Enterprise Edition installed.
You must be logged in to view attached files.January 5, 2021 at 08:15 #29760support
KeymasterNo problem, please share a screenshot of the Help->About VisualGDB window so that we could see what is going on.
January 6, 2021 at 04:37 #29765OSTerhase
ParticipantWell we are using the USBDriverTool as a standalone application, downloaded directly from your website from here:
https://visualgdb.com/UsbDriverTool/
I thought I have to install VisualGDB-5.5.104.3936.msi which would fix the issue we are having but it didn’t. Until I realized, that the USBDriverTool is included within the VisualGDB-5.5.104.3936.msi package.
It works now but we have students working with the USBDriverTool which do not have Visual Studio installed on their private computers. What’s the solution for them if they do not have a license for Visual Studio? As far as I know the VisualGDB-5.5.104.3936.msi package does not support the Visual Studio Community editions?
January 6, 2021 at 04:51 #29766OSTerhase
ParticipantMy fault, it’s the express editions which are not supported but the community editions should work.
January 6, 2021 at 08:12 #29769support
KeymasterSorry, our support only covers our paid products such as VisualGDB. We will eventually release an updated stand-alone version of USBDriverTool, however we are not able to guarantee any timelines for it.
Edit: we have updated the stand-alone USBDriverTool to use the new timestamp server.
This reply was modified 5 years, 2 months ago by
support. Reason: updated USBDriverTool
