Updating GDB executable?
Sysprogs forums › Forums › VisualGDB › Updating GDB executable?
  • #33135
    Johanan
    Can anyone explain what is wrong and what should be done to fix this?
    How to “Upgrade GDB executable”?
    <hr />
    Warning: your GDB did not accept a breakpoint in E:\MyWork\WaterOnDemand\ESP32\WaterOnDemand\Output\DOIT_ESP32_DEVKIT_V1\Debug\sketch\Sensors.cpp, but accepted it using the name-only syntax (Sensors.cpp).
    VisualGDB will now use short file names instead of full paths to set breakpoints.
    This might cause strange bugs if you have multiple files with the same name in different directories.
    Please consider updating the GDB executable in your toolchain/system.
    <hr />
    #33137
    According to our records, you do not have an active support period, hence we will not be able to help you. If anyone else wishes to help, they are welcome to post in this thread.
    #33143
    Johanan
    Renewed. (Expired 3 days ago, BTW).
    #33146
    According to our records, your support is still not active. If you believe this is a mistake, please contact our technical support with your license details.
    #35381
    Johanan
    Tring to start a new project for NXP Rt106XX, i follow the instruction, but import of the SDK give this message:
    the SDK you’ve specified doesn’t contain any linker scripts
    If I ignore it, it returns to device selection.
    Any Idea how to build a project for this chip?
