Update 5.6.107.4663-r7 download file size error
Sysprogs forums Forums VisualGDB Update 5.6.107.4663-r7 download file size error
  • #33027
    arrow201
    VS: 2020, V17.3.0 Community
    Noticed there was an VisualGDB update to 5.6.107.4663-r7 and went to install it:
    Tools | VisualGDB | Manage VisualGDB Packages | Updates
    As per the enclosed screenshot, I got a “Unexpected download size: 54587392, expected 54583296” error when attempted to download it.
    The exception details are:
    VisualGDB version: 5.6.106.4622
    System.Exception: Unexpected download size: 54587392, expected 54583296
    at si1.p1(String a, Int32 b, Int64 d, String c, String e)
    at si1.v1(URLWithParameters[] b, Int64 a, String d, Int32 c, nr e, String f)
    at si1.k.a(nr a)
    at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass2_0`1.<RunAction>b__0()
    trace=[si1.p1:0, si1.v1:1162, si1+k.a:0, VisualGDB.Common_GUI.WPF.ItemizedProgressWindow+<>c__DisplayClass2_0`1.<RunAction>b__0:0]
    Thanks.
    #33029
    Sorry about that. We discovered a glitch in the original 5.6r7 release a few hours after it was published. As it would only affect VS2008 users, we simply replaced the original installer with a fixed version. Other than the VS2008-specific fix, both installers are identical, so we reused the same revision number.
    If you are seeing this message, VisualGDB has downloaded the package catalog after the release, but before the fix. As a workaround, you can download the new VisualGDB update manually here. Other packages are not affected by this, so the error can be safely ignored.
    #33030
    arrow201
    The manual update worked fine. Great product, great support.
    Thank you!
