UnitTest with build on Host via CrossTool
Sysprogs forums › Forums › VisualGDB › UnitTest with build on Host via CrossTool
  • #11244
    ThomasM
    Hi there,
    I’m currently developing for a Intel Edison and would like to get a unit test running. Because the project will expand more and more it would be nice to use the cross-compile method.
    In the tutorial (https://visualgdb.com/tutorials/tests/googletest/) a MSBuild for the unit test is used. It says that it’s also able to build with a cross toolchain tool. So I choosed the “Build the project locally with a cross-compiler” and got an error message after clicking finish:
    Tool arguments: -Wl,--start-group "C:\Users\Thomas\AppData\Local\Temp\/VisualGDB_ToolchainTestProgram.o" -o "C:\Users\Thomas\AppData\Local\Temp\/VisualGDB_ToolchainTestProgram" -Wl,-gc-sections -Wl,--end-group
    d:/toolchain/i686-pokysdk-mingw32/usr/bin/i586-poky-linux/../../libexec/i586-poky-linux/gcc/i586-poky-linux/4.8.2/ld.exe: cannot find crt1.o: No such file or directory
    d:/toolchain/i686-pokysdk-mingw32/usr/bin/i586-poky-linux/../../libexec/i586-poky-linux/gcc/i586-poky-linux/4.8.2/ld.exe: cannot find crti.o: No such file or directory
    d:/toolchain/i686-pokysdk-mingw32/usr/bin/i586-poky-linux/../../libexec/i586-poky-linux/gcc/i586-poky-linux/4.8.2/ld.exe: cannot find crtbegin.o: No such file or directory
    collect2.exe: error: ld returned 1 exit statu
    When I try to build the project the <ctype> and <string> headers are missing and the compilation process fails. How can I fix the problem? It seems that the GoogleTest Framework is stored in C:\Users\Thomas\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.googletest\. My files and the Cross-Toolchain are in a different path.
    Is there anything special compared to the build toolchain described in https://visualgdb.com/tutorials/linux/edison/ ? Maybe a special unit test tutorial for the Intel Edison 😉 ?
    Greetings,
    Thomas
    **** EDIT ****
    Forgot to say: I need the cross-compile toolchain for the compile process. The edison itself takes to much time for the compile process…
    • This topic was modified 9 years, 4 months ago by ThomasM.
    #11247
    The Edison toolchain might require an explicit “–sysroot” argument. Please try specifying it via additional command line flags for both compiler and linker (see the toolchain documentation or included examples for the correct sysroot value).
    #11248
    ThomasM
    That’s right. The tutorial suggested me to use the MSBuild instead of the GNU build. I choosed the GNU and set the sysroot settings as usual. Worked.
