Unable to start debugging
Sysprogs forums Forums VisualGDB Unable to start debugging
  • #30568
    DonMilne
    I get the following when I choose Debug|Start debugging in Visual Studio 2015 (VisualGDB 5.6).
    “System.TypeLoadException: Could not load type ‘BSPEngine.RemoteTool’ from assembly ‘BSPEngine, Version=5.6.1.1, Culture=neutral, PublicKeyToken=8f764369eb712693’.”
    I thought perhaps there was something wrong with the unit under test, so I switched to another device and got the same error. In any case it reads like a tools config problem, not a hardware problem.
    Any suggestions?
    p.s. I have two current support licenses in my time, my company has at least one other.
    • This topic was modified 4 years, 10 months ago by DonMilne.
    #30573
    It looks like you are using a relatively old preview build. Please try updating to the latest one: VisualGDB-5.6.1.4124.msi
    #30576
    DonMilne
    Thanks for the prompt response.
    Strange, I could have sworn that I updated it just the other day, but it was actually in early March – and in any case I should have remembered that I was using a test build!
    So I’m sorry about that, and I confirm that the problem does in fact go away when I install 5.6.1.4124.
