Sysprogs forums › Forums › VisualGDB › unable to locate sdkconfig.h when generating phy_init_data.bin
- This topic has 3 replies, 2 voices, and was last updated 7 years, 6 months ago by
March 18, 2019 at 10:58 #24315
andreapedica
I am facing the follwing issue: I’ve set up my ESP32 project in order to generate the phy_int_data.bin binary during compile time.
The problem that occurs is as follows (copied from compiler output):
[169/1001] Generating phy_init_data.bin
FAILED: esp32/phy_init_data.bin
cmd.exe /C “cd /D D:\data\projects\ESP32\SDUF\SDUF\VisualGDB\Debug\esp32 && C:\SysGCC\esp32\opt\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -x c -c -I C:/SysGCC/esp32/esp-idf/v3.2-beta3/components/esp32 -I C:/SysGCC/esp32/esp-idf/v3.2-beta3/components/esp32/include -I D:/data/projects/ESP32/SDUF/SDUF/VisualGDB/Debug -o phy_init_data.obj C:/SysGCC/esp32/esp-idf/v3.2-beta3/components/esp32/phy_init_data.h && C:\SysGCC\esp32\opt\xtensa-esp32-elf\bin\xtensa-esp32-elf-objcopy.exe -O binary phy_init_data.obj phy_init_data.bin”
C:\SysGCC\esp32\esp-idf\v3.2-beta3\components\esp32\phy_init_data.h(18,23): error : sdkconfig.h: No such file or directoryDo I have to manually specify the location of the sdkconfig.h file? If yes, which variable should i config and in which projet configuration file?
For your convenience:
- VisualGDB version is 5.4 build 2737
- ESP-IDF v3.2-beta3 (but occurs also with previous stable releases)
Thanks, Andrea
March 18, 2019 at 17:13 #24322support
KeymasterNormally, the sdkconfig.h file should be handled by the ESP-IDF build system itself. The only advice we could give is to try creating a project based on GNU Make instead of CMake (it uses a different set of build scripts) and if it doesn’t work either, check if the problem can be reproduced by building from command line.
If it doesn’t work from command line either, please check with Espressif – it might be a bug on their side. If it works when built manually, but fails under VisualGDB, please let us know both build command lines and we will investigate.
March 25, 2019 at 14:20 #24454andreapedica
your suggestion to switch to GNU compile system actually solved the problem in VisualGDB under VS.
Whenever possible I will check also if problem is present outside of VisualGDB, in that case I will check on ESP-IDF side.
Thanks for your help.
March 25, 2019 at 17:48 #24457support
KeymasterGood to know it works. Espressif did previously mention that the CMake build scripts are missing some of the advanced features supported by their Make scripts, so it makes sense. Either way, VisualGDB does and will support both build systems, so that you can always find the one that works.
